just throwing it out there lol hope the new idlers work for ya bud
Me too, but if my tax return were to be 6K
Make sure it has a garage so you have a place to park your car.
Matt the way the belt looked tells me it is too tight. When i was shredding belts it was due to the S/C and P/S [pulley alignment. When that was corrected, i started snapping belts in half, no more shredding. Yours looks similar to that. Id say get a slightly longer belt
lmao yea i know right im looking for an oversized 2 car so i can put carpet in it like billy and be comfortable while working on it
what size idlers do you have right now? go with smaller or larger to either free up some belt or take up slack to change belt sizes
I have 2x of the idler pulleys that came the GIjoe 8 rip setup. I believe when I measured them they were 85mm or 86mm. One of them is no longer usable though as it is the one that got broke off. I ordered 1x 76mm and 2x 90mm idler pulleys from Thrump_rrr, but my thinking was to just take the gripper block off.
About the P/S pump though, is there a way to tighten up the shaft so that the pulley doesn't have the 1/32 in out slop?
I realize it doesnt help you but i am running all 76MM pulleys which helped me find a correct belt size. It gets easier the shorter the belt gets rather than the longer it gets so it may be something you can look into. You also can play with the water pump pulley if your still on a mechanical one, though from the pics it appears to be a meziere.
As far as the PS goes, i have no slop in mine at all. it did have to be moved out a bit to get it in alignment
I don't remember having any "in and out slop" in my water pump pulley. But I wouldn't think that is causing you any problem since it is a smooth pulley and there is nothing that the belt tracks on with it. As for the power steering pump, you can try to crank down the pulley a little more, but honestly, if it is lined up I wouldn't jack with it because you can screw up your power steering pump.
Hey Matt,Well after getting my new pretty Thrump_rrr 90mm idler pulleys in we put them on the car and took off the Thrump_rrr S197 Saleen Extension Arm. I liked the extension arm and it really did remove all slip but on the down side the belt kept getting caught between the extension arm and the blower pulley causing the belt to either snap or shredd. Or an idler pulley boss to get ripped off. So off it has come. We started up the car and the belt float is gone and it appears that the belt problems are gone, however I didn't get to take it for a road test as when putting on the new timing cover we cut the valve cover gasket. I had to order a new one and it won't be here till Tuesday.
Anyway, it looks like my car doesn't like the S197 Saleen Extension Arm. I'll be having mine for sale here soon.
you wouldnt crank down on the p/s pump, you would pull it out toward the radiator. Peter and i moved mine out to correct the belt. The pulley does not sit flush on the pump.
I did not crank down on the p/s pulley. We actually used a laser level to make sure that all the pulleys were lining up grove by grove. There is some slight in and out movement on the pulley but less then 1/32" I would say, it is about enough that you can feel it pushing in and out but you can't see it.
That would explain the longer belts.Hey Pete
I am running the 10% over drive I/W crank pulley and the V10 water pump pulley on the Eh2o pump. The tensioner has the 76mm idler pulley as well. The other pulleys are all the ones that come with the GIjoe 8 rib setup.
...I'll hold off on selling the extension arm.
