- Joined
- Dec 17, 2009
- Posts
- 62
- Reaction score
- 1
Billet Aluminum Differential Bushings for S550 Mustangs
BK050
Reduce wheelhop, eliminate pinion rise, and enhance the rear stability of your 2015 and newer Mustang by eliminating differential movement with Billet Aluminum Differential Bushings from BMR Suspension. Stock rubber bushings with voids are great for minimizing NVH, but cause wheelhop and damage to rear suspension parts. Designed from 6061-T6 billet aluminum, these differential bushings eliminate deflection, differential movement, and pinion rise that you experience with the factory bushings. BMR Billet Aluminum Differential Bushings (BK050) transfer more power to the differential by not absorbing it with wasted movement. BMR designed the BK050 for max effort street performance, drag race, and handling applications, making them the perfect wheelhop solution for performance-based S550 Mustangs. Each bushing is CNC-machined to strict tolerances, which ensures high quality and a perfect fit. These bushings eliminate all differential movement, increasing handling stability and giving you a much-improved overall feel in any performance driving situation. Installation time is about 3-4 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
