IF you lower the car, you better have stiffer springs. Lowered cars + soft springs = more prone to bottoming out, or hitting bump stops etc. For the low cost of your typ lowering spring, it's really a moot point.
Oem Ford springs are way too soft. Even if cut, using the above example in post #18, only results in a 287 /269 = 6.7% increase, which is not very much. And oem springs are no where near 269 lbs, way less than 1/2 of that.
I predict that oem springs, after cutting, + oem struts + shocks will have a tendency to bottom out. Stand on the brakes, and the oem setup will nose dive on the front, and lift severely on the rear. Mash the gas from a light, and back end squats, front end lifts.
2 summers ago, I ran into some asian ricers at the local coffee shop....all with cut springs. I asked em how that worked out. Their reply was... 'not a smart move on our part'. But they had cut way too much off.
