CMDP DIY
06Torch
Houston, TX
good buy !
Yeah, I asked locally what welding them would run me and I got a quote of 70 bucks. That plus the cost of the extra pair of CMPs didn't seem to be worth it for me. So, I started looking at other options and got lucky, I guess.
So, $30 shipped to anyone who is interested in factory CMPs.
Gerardo
J
JP229
Guest
So for the DIY's, did you port match heads and intake? I stuck a boroscope down my intake runner and saw a nice little ledge. How much grinding did you have to do?
I am wanting to do this whole proccess within the next few weeks. Possibly turn down some plugs myself on a lathe and just press fit since i'm also a little sketchy on the whole quick steel/fuel/flaking BS...
waketek516
Pedal to the Metal!
Costa Mesa, CA
Anyone find out what these are for?
Steeda Autosports Charge Motion Delete Plugs
http://www.summitracing.com/parts/SDA-555-3148/
06Torch
Houston, TX
According to this, you use them to plug the holes left by the rod that holds the butterflies.
Gerardo
Charge motion delete plugs for use with Steeda charge motion plates.
Are you bummed that you bought a vehicle and found out that you couldn't use Steeda's charge motion plates? Well, Steeda has the prescription for happiness! Steeda's charge motion delete plugs eliminate the butterflies, giving your intake air a smooth shot into the head. Machined from quality materials, these plugs are a great upgrade for your ride. As used on Steeda's Q350 Mustangs, Steeda's plugs reduce turbulence and improve airflow in the intake path for more horsepower and torque! Steeda's charge motion delete plugs require computer recalibration for use.
irishpwr46
Official Site Vandal
NYC
no they will not. those are for 2009-2010 because the Charge Motion Plates were integrated into the intake manifold. its a differetn setup all together
1FastS197
Hickory MS
i got a buddy who is a machinist... does anyone see a problem in welding the holes up and smoothing them down and not using the quick steel?
SilentScope
Chemist by profession
South Florida
okay, just not sure of the quick steel... would make for a bad day if it came out and went down into the head...
personally, i wouldnt do the quick steel. If you get boosted, and some falls off... bad news.
Get em welded, itll work and be safe.
1FastS197
Hickory MS
oh yeah, thats what i am planning on... i want to see if i can drill and tap for some direct nitrous lines... and gonna do a little porting as well... we'll see how it turns out.. not sure on drilling and tapping on this pot aluminum...
