Custom 8.8 build
Discussion in '2005+ Ford Mustang v6 4.0L Tech' started by Benwhite911, May 11, 2017.
  1. Benwhite911
    Benwhite911 V6'ing & Dealing With It
    128
    Nov 27, 2016
    Cape Coral, FL
    I have the opportunity to buy an 8.8 rear end housing off of a friend for $100.00. I want to build it with a Posi Differential and 4.10 gears. I'm new at this, so I have no idea what parts or materials are needed to complete a task like this. Is there a list anyone could point me to a list that would outline everything needed to build an 8.8 Rear End?
    Just to clarify. The bare housing is what I would be buying. It comes with nothing.
  2. 0BlackBeauty5
    0BlackBeauty5 Junior Member
    17
    Jan 17, 2017
    No gears or axles?
    Sent from my SM-G935V using Tapatalk
  3. Benwhite911
    128
    Nov 27, 2016
    Cape Coral, FL
    Correct. Just the Housing. Nothing in it or attached to it.
  4. stkjock
    stkjock ---- Madmin ---- Staff Member
    36,020
    125
    Jul 10, 2007
  5. RocketcarX
    RocketcarX 95% of my weight is fuel
    1,602
    Jul 19, 2011
    Burton Texas
    American Muscle will have pretty much everything you need in kit form
  6. TexasBlownV8
    TexasBlownV8 Formerly TexasBlownV6
    4,851
    Apr 4, 2008
    Central Texas
    If you're looking for stock components, like axles, gears, and the differential, members here often sell good used ones.
    The one thing in the empty case that I hope is still there are the differential bearing caps. Everything else can be (and often is) replaced.
    A far as how to do it, you kind of should know what you're doing. There are several critical steps that must be done right in terms of measurements and clearances, in addition to torque specs. Find someone who can do it for you. I usually tell people what parts to get and then do the work with them or for them.
  7. Benwhite911
    128
    Nov 27, 2016
    Cape Coral, FL
    I kind of figured I'd be biting off more than I can chew by trying to undertake this all by myself. I appreciate your honesty.
  8. tigerhonaker
    tigerhonaker Bullitt Mustang Owner
    72
    6,449
    12
    Apr 11, 2009
    TN
    Ben,
    Unless you are a really great mechanic with years of experience in driveline and rear-ends I would not even consider doing this yourself.
    It is one of those things that is either (Right or Wrong) !!!
    Terry
Share This Page
