Car looks good. Running well too.
So an 11.00....?
UPR K member....jus sayin...
So an 11.00....?
Depends on if I can get a smokin deal on one or what hint hint hint.
I feel like I'm hooking on the 17" ET streets pretty well, but if I were to go with say 15" ers, would my 60' get better with no other changes or would that just allow me to launch at higher RPM's with better traction? I'd say 1.4xx range would be obtainable if I can get 1.51x on my current setup, right???
Thanks Sharad. I really didn't want to have to do the sway bar relocation deal. I don't know enough about it at this current point. Initially I was going for great handling and light track duty. I have a Sam Strano 3 way adjustable Sway in the rear. I am surely leaving some ET on the table with the wheel setup alone. After feeling how light the front wheels can be vs. my 55-60ish lb/side up front, it seems silly not to do it. For the amount of time I go to the track though, it seems silly to spend 1800 on strip tires and wheels though as well.
No not really. It felt good. It just seems like maybe I wasn't getting the same power in the lower gears as normal, but it really picked up on the big end????? I don't know I didn't really look at it too much until I saw what other people cutting 1.4's and trapping 128 were running.
Edit:
I went back and looked, I think I found my shortcomings. Most of the people with similar hook and speed are running faster because most are on Auto's. Guess I need to row faster
Guessing you didn't know my setup before and I didn't post changes to my setup in post #110. I have changed the pumps and injectors out for more capable pieces to run e85. I made another 10hp/20trq on slightly less boost as last time with only a degree or so of timing added back in. I didn't want to get agressive with the timing. Well at the track that day I turned up boost about another psi and only peaked 10.2 psi through the run. The previous 11.071 run actually had the wastegate dumping (now its returned) and would slowly creep up in 4th to over 10psi.
On the dyno the boost stayed level both before and after the e85. At the track before the boost would slowly creep up especially in 4th. This time it just hovered around 10psi in 4th going through the traps. I'm guessing at the track I was making somewhere on the neighborhood of 490/520
