Gt500 Fuel Harness
Discussion in 'Mustang Chit Chat' started by TzReddy, Jan 7, 2018.
  1. TzReddy
    TzReddy forum member
    470
    Sep 6, 2010
    Florida
    I bought his harness used and I have a gt500 fuel hat. 2 wires are cut on the harness and was wondering where they go. Also seeing both are gt500 harness and hat the plug is direct but the plug on the outside of the cover I am assuming gets wired to the original plug from stock harness. Do they sell a diy plug for that or can I just solder them together and if so which wires go where?[​IMG][​IMG][​IMG]
  2. slackinoff
    slackinoff Senior Member
    794
    Feb 14, 2016
    East Texas
    I don't know much about this, but the cut wires look like positive power. If so, I think I would soldering them. Not sure on the plug.
    Sent from my SAMSUNG-SM-T377A using Tapatalk
  3. TzReddy
    470
    Sep 6, 2010
    Florida
    Bump
  4. TzReddy
    470
    Sep 6, 2010
    Florida
    Double bump
  5. DiMora
    DiMora More Is Better
    47
    801
    Aug 22, 2010
    Fayetteville, GA
  6. DiMora
    47
    801
    Aug 22, 2010
    Fayetteville, GA
    The seller might've had a Kenne Bell or other brand Boost-A-pump wired into there also...which may throw you off with pieces of wire that are different colors
  7. ILW84U
    ILW84U Senior Member
    58
    1,119
    Apr 14, 2007
    Edmonton, Alberta
    The wires in the first pic just need to be soldered back together. They are the power wires to the FPDMs. The larger plug goes to the fuel pump & the smaller 2 wire plug goes to the crossover pump on the passenger side saddle of the fuel tank. There are 2 wires that need to be crossed over on that plug. I can grab the instructions for that later & post them if you need.
  8. DiMora
    47
    801
    Aug 22, 2010
    Fayetteville, GA
  9. TzReddy
    470
    Sep 6, 2010
    Florida
    If you can that would be great
  10. TzReddy
    470
    Sep 6, 2010
    Florida
    Do I have to extend the wires on the 2 wire plug to reach the passenger side?
  11. ILW84U
    58
    1,119
    Apr 14, 2007
    Edmonton, Alberta
  12. TzReddy
    470
    Sep 6, 2010
    Florida
    The stock plug and the 2 wire plug in the picture aren’t the same. They won’t plug into each other. Do I need to buy a different plug to rearrange the wires?
  13. TzReddy
    470
    Sep 6, 2010
    Florida
    Or can I just solder the together?
  14. ILW84U
    58
    1,119
    Apr 14, 2007
    Edmonton, Alberta
    I did mine 8 years ago but I am pretty sure the plug was the same. Maybe someone else can answer.
  15. TzReddy
    470
    Sep 6, 2010
    Florida
    Anyone??
  16. slackinoff
    794
    Feb 14, 2016
    East Texas
    I would just solder and get on with it man
  17. TzReddy
    470
    Sep 6, 2010
    Florida
    Thats what I am going to do. I will line up the 2 wires from the gt500 harness with the 2 wire plug and pull the 2 wires out of the original harness and solder together. Hope they line up right as Ive read that the Ford directions are wrong on the color cordination
  18. slackinoff
    794
    Feb 14, 2016
    East Texas
    Oh damn, well if you can't find anymore research on the colors. At least it's a 50-50 odds. If it's wrong hopefully it only throws a code or something. Worst would be to burn up a controller. Wish I had more info for you.
  19. TzReddy
    470
    Sep 6, 2010
    Florida
    I believe if its wrong it only shows false reading on gas gauge.
    slackinoff likes this.
  20. slackinoff
    794
    Feb 14, 2016
    East Texas
    Oh then fire the old iron up and get cracking.
Share This Page
