Will the GT500 pumps fit on a stock 2007 GT fuel hat with no modifications?
Also can I get at least one pump running on the stock fpdm setup? Or is it an all or nothing deal?
I think this should answer your questions. http://www.s197forum.com/forum/showthread.php?t=129255
Thanks Bruce. So if Im understanding right, no modifications are needed on the electrical side (besides a wiring upgrade) and I can run this on the stock fpdm?
For some reason I thought Ill need a fpdm for each fuel pump to make this work.
My final power goal is 600-650whp on pump gas but I would like it to be capable of 700whp so I have room to grow. I got the GT500 pumps and a set of 60lb injectors from forum members and Im trying to make it work on the stock fpdm setup. But I wasnt sure if the stock fpdm can run both pumps.Ford overbuilt the design for the gt500 system based on their previous experience with older svt cobra dual pump setups using the pre-2004 fpdm that had issues running 2 pumps with out modifying the coil inside. The 3v fpdm is much more robust and is capable of driving up to two 255lph pumps up to 30amps and has thermal shutdown protection for the circuit. Having a dedicated driver module for each pump is of course more efficient power wise.
The frpp/gt500 dual fuel pump hat has a different connector and requires a dual fpdm harness and second fpdm to run. The work around to save $ is modifying a stock GT hat with 2 pumps and then upgrading the wiring to the single oem fpdm.
What are you trying to build/what kind of power are you looking to support?
