Hot Rods or Detroit Rockers
Discussion in 'WTB Items and/or Parts' started by tbrock, Oct 8, 2017.
  1. tbrock
    tbrock Senior Member
    927
    May 3, 2009
    colorado
    4.6 3v looking for Ford Racing Hot Rod cams or Brenspeed Detroit Rockers.
  2. tigerhonaker
    tigerhonaker Bullitt Mustang Owner
    72
    6,474
    17
    Apr 11, 2009
    TN
    I see from your description you are running (Saleen SC Stage 3 with 3.0 pulley).
    Just so you know the Brenspeed Detroit Rocker cams come two ways.
    1-for S/C applications.
    1-for Non S/C applications.
    I have ran them and know many other guys that have ran them over the years in both applications.
    They are an easy cam to live with.
    I tried a great many cams in mine over the years as I kept changing/modifying mine.
    The Detroit Rocker Cams I di like when I ran them.
    Terry
  3. tbrock
    927
    May 3, 2009
    colorado
    Thanks Terry I'd prefer the SC version.
  4. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Todd,
    I think you will enjoy those.
    Like I said I ran them and a close buddy of mine runs them with his Paxton S/C.
    A lot of guys have ran them back when Brenspeed 1st introduced them to the market.
    They sound better than stock cams which is a plus.
    Especially if a person is running the more straight through exhaust.
    Seems as I recall the power with them comes on around 3,000 to 3,500 Strong !!!
    Enjoy,
    Terry
  5. AndrewNagle
    AndrewNagle forum member
    2,557
    34
    Jun 20, 2008
    Mountains of NC
    This was on the box for my new Detroit Rockers SC version
    [​IMG]
  6. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Well my man just making a (Guess) I'd say those were for the Normal Aspirated Engine.
    Not the S/C Cams ..........
    Just for those interested you actually can run either set of the Detroit Rocker Cams if you started out with No-Supercharger and then Up-Graded to a S/C.
    Terry
  7. AndrewNagle
    2,557
    34
    Jun 20, 2008
    Mountains of NC
    say it isn't so...............
    thinking the part # DET3VSC was SuperCharge version
    http://www.brenspeed.com/detroit3vsc.html
  8. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Well buddy,
    When I saw the pictures I thought you were showing me that Brenspeed (Marked-Out) the S/C part #.
    Meaning they were (Not) the S/C cams but the Normal Aspirated Cams.
    After reading your New Posting ...........
    I take it that Brenspeed (Actually) was Marking that Box so they and you knew they were the S/C Cams !!!
    Honestly buddy it is somewhat confusing to be Matter-of-Fact about it.
    ONLY, Brenspeed knows and Hopefully the Customer which Detroit Rocker Cams they really are in the box.
    Terry
  9. AndrewNagle
    2,557
    34
    Jun 20, 2008
    Mountains of NC
    Yeah I confused it, my shop marked it out when they put the Hot Rod's in the box
    All Good
    Andrew
  10. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Excellent :clap:
    T.
  11. tbrock
    927
    May 3, 2009
    colorado
    Thanks the plan is to go up one pulley size when I change out the cams. Stock bottom end so trying to stay around the 500 at the wheel power level.
  12. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Todd,
    Just as a Heads-Up buddy.
    Stay around that power or maybe a little less.
    Especially if your Drag-Racing with Drag-Radials which put a Real-Load on the Bottom-End.
    I'm telling you as a car buddy that unless you have a pretty darn good reserve of monies and the engine ,stock engine, puts a rod through the side of the block.
    Your going to have some really super costly repairs.
    Terry
  13. tbrock
    927
    May 3, 2009
    colorado
    Yes I'm maxed out on what I want on the stock rods/pistons. I mostly run on the road course with an occasional trip to the 1/4 on street tires. At some point I'll build it. I've got 40k miles on my current setup, always use good gas and the tune I'm running is safe.
  14. tigerhonaker
    72
    6,474
    17
    Apr 11, 2009
    TN
    Todd,
    Better SAFE than maybe ..... Real-Sorry. :imo:
    T.
Share This Page
