HRE 945R 3 Piece Forged Aluminum Wheel Set & Vredstein Ultrac Sessanta Tires
Legend Shaker
Chicago, IL
Maybe someone has a BMW 7 series or a Range Rover that could use these?
I have up for sale today, a beautiful set of HRE 945R 3-Piece FORGED Aluminum Wheels with brushed clear coat finish, in excellent condition!
These Wheels & Tires have only 1500 miles of use (mostly highway). ZERO CURB RASH ! These also come with a set of high speed rated, high performance,
Vredstein Ultrac Sessanta tires, designed by Giugiaro (Designer for Lamborghini). I paid extra to have Buttler Tire of Buckhead GA, high speed balance these (NOT cheap...).
These will accept aftermarket big brake kits (6 Piston Caliper Baer, Brembo & Stop-Tech (Saleen) with 14 and 15" rotors with zero clearance issues).
These cost over $11k when new !! For sale: $3995 FIRM
Shipping: Continental USA ONLY. Actual cost at time of sale. I will require a zip code to calculate shipping fees.
Local pickup in Atlanta, GA accepted.
I will accept payment by discrete (gift) PayPal, Cashiers check from Major Bank or Credit Union, USPS Money Order or Cash for local pickup.
Fittment: BMW X5, 6 & 7 Series, Range Rovers, and Rolls Royce.
Front Wheel: 9" X 22" (3" Chromed outer lip)
et+33
pad height 0.40
Rear Wheel: 10" X 22" (4" Chromed outer lip)
et+22
pad height 0.35
Bolt Pattern: 5 x 120 mm (5 x 4.75")
Center Bore: 72.56 mm (Hub Centric)
Centers: FORGED Aluminum
Center Finish: Brushed Aluminum/Clearcoat Finish
Inside Barrel/Rim Finish: Black Powder Coat
Valve Extensions:YES!
Connecting Fasteners: ARP (The best...)
Tires: Vredstein Ultrac Sessanta
Front: 265/30 ZR22
Rear: 295/25 ZR22
I also had these mounted on my 2005 Ford Mustang "Saleen" by redrilling the bolt pattern into the front hubs, rotors, rear axles and narrowed the Ford 8.8 rear end 3" (By Moser Engineering) this is also available to purchase separately... (Rear is for 05 + Mustangs Only)
Legend Shaker
Chicago, IL
damn, these won't fit my 14 535?
glws man
Actually... They would.
BMW 5 Series 2014, 535i 304HP
Tire
Rim
PCD
THD
CB
245/45R18 8Jx18 ET30 5x120 M14 x 1.25 72.6
245/50R18 8Jx18 ET30 5x120 M14 x 1.25 72.6
245/40R19 8.5Jx19 ET33 5x120 M14 x 1.25 72.6
Mine are 5x120mm bolt pattern with 72.56mm center bore and the offsets will work out fine at +22 front and + 33 rear
worst case? The front could use a 5 or 10 mm hub centric spacer
I was about ready to just buy my wife a 7 Series to put these on!
Aren't the new 5 series using the 7 series platform/frame??
Mr. Q
North of Seattle, WA
I thought they were different platforms... I was looking into whether these wheels would fit, but got busy with work.
it would be for the wife, so if she likes the wheels i'll get them for her. :)
Legend Shaker
Chicago, IL
These will fit most BMW's. I think that they would look best on the 7 series or X5, X6!
Also fit range rover and most RR perfectly.
Note: HRE sells different center caps for these, if you don't like the "RR" centers.
