Looking to buy a New Touchscreen radio to change my shaker 1k unit
Discussion in 'Tunes!' started by Speed+Clinic, Aug 25, 2016.
  1. 08gtbullitt151
    08gtbullitt151 forum member
    50
    Feb 4, 2016
    Sorry, I meant does it show up on your touch screen, I have the same app and dongle. Does it show the info on the stereo?
    Sent from my SPH-L720T using Tapatalk
  2. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    Yes it shows up
  3. tightwhite08
    tightwhite08 Junior Member
    47
    Jul 15, 2016
    I like how this looks. Link says fits 2010 but I assume it'll also fit my 08 Shaker 500 too. Did u add an amp?
  4. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    Yes it will fit. My car is 07 with Shaker 500.
  5. tightwhite08
    47
    Jul 15, 2016
    On its way! I have read a couple places that a different harness is needed to get the amps/subs in the shaker 500 to work correctly. Any issues with sound quality or subs/amps?
  6. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    Well you need a 5v regulator for the shaker amps or it's gonna make a loud pop everytime you start the car.
    Mine came with a prewired harness already so it was straight up plug and play. The only thing I did need to tap was the dimmer wire which I teed off the wire from the info/setup/reset switch.
  7. 46addict
    46addict 13726548
    1,236
    Aug 25, 2016
    Lawrenceville, GA
    Do you remember what colors the dimmer wire had?
  8. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    Off the top of my head it was the white with orange stripe.
  9. tightwhite08
    47
    Jul 15, 2016
    Got the install started today and all went will with the supplied harnesses. One question, did you connect the OEM radio antenna to the HU? I see the tiny antenna the HU comes with but can't imagine it picks up any decent signal. Looking at the metra 40-cr10.
    Besides that waiting on 12v-5v regulator and all should be good. A lot of extra wires on the xtrons but I think its just extra for supported options I am not using.
  10. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    I think I had an extender or an adapter already installed from a previous headunit so I may have overlooked that part.
  11. tightwhite08
    47
    Jul 15, 2016
    Install complete and loving it
  12. nbk13nw
    nbk13nw forum member
    271
    Feb 18, 2015
    Do you know what dash adapter you used for the install? I was thinking that the Metra 99-5807 should fit the XTRON, Pumpkin or JOYING units.
  13. o2sys
    o2sys forum member
    4,108
    Jun 26, 2011
    NY/NJ
    My Xtron unit doesn't need any dash kits. It's made to fit the opening and reused the shaker brackets.
  14. SeanD
    SeanD forum member
    133
    Sep 8, 2007
    LaSalle, ON, Canada
    How is the performance of this unit. I am looking at the new Android 6 units with 2/32gb memory and octa-core processor instead of this one, cause I just want to future proof it.
    If I new that the Xtron For unit would be upgradable via a proc replacement card, I would jump on it now. It looks like your unit has the Rockchip PX3 proc and I recently saw a video about a new PX5 replacement card that is just plug and play and will upgrade your unit. There doesn't seem to be a clear answer if the public will be able to purchase this card or not.
  15. SeanD
    SeanD forum member
    133
    Sep 8, 2007
    LaSalle, ON, Canada
    Metra 99-5812 is the double din kit you want, but it will not fit any of the mentioned Android HU without modifications. These Chinese HU's are bigger the north American double din standards, so you will need to modify the kit a little, so the HU site perfectly.
  16. nbk13nw
    271
    Feb 18, 2015
    Thanks SeanD. I figured it wouod need some finessing.
    Sent from my SM-G925V using Tapatalk
  17. Saleen304
    Saleen304 forum member
    447
    Aug 11, 2011
    Any more installs with pics and tips? My pioneer unit just went out so I ordered this one from Amazon. Really nervous about a Chinese made stereo. I am replacing an aftermarket pioneer unit so I don’t have the brackets from the shaker for install. Just want to see what others had to do to make it work.
    Android 7.1 2GB RAM Fit Ford F150 F250/350/Edge/Fusion/Mustang In Dash DVD Player GPS Navigation Stereo Radio BT Steering Wheel Ctrl Wifi Support 4G DVR TV DAB+TPMS Amazon.com: Android 7.1 2GB RAM Fit Ford F150 F250/350/Edge/Fusion/Mustang In Dash DVD Player GPS Navigation Stereo Radio BT Steering Wheel Ctrl Wifi Support 4G DVR TV DAB+TPMS: Car Electronics
  18. Saleen304
    447
    Aug 11, 2011
    Installed it this evening. 1 word. Disappointed. I like the way it looks in the dash and the hookup was pretty easy. Once I booted it up is when I found my disappointment. Interface isn’t as responsive as I expected and it takes multiple attempts to get the small touch points on top to register. Very difficult to swipe and scroll without it selecting an item. Integration with iPhone and Apple Music is awful. No album artwork. The mirror function doesn’t work at all. Looks like I will be looking at different option.
Share This Page
