06 T-RED S/C GT
The research I did indicated the extra overall ( excess) loudness came from the high flow catted H..and not the JBA LT's. As far as the drone, my guess is the combo of the LT's + high flow catted H.
The FRS-500S are guaranteed drone free.... provided the rest of the exhaust is oem.
Ehhhh. I get a little bit, but only at very specific RPMs and under load. It rarely happens, so it's a nonissue, but it still occurs.
If you do get some drone, it might be at 1900-2100 rpm, and going up an incline, hill, or steep hill. That would really put a good load on the eng. It's a good muffler, albeit expensive.
Changing midpipes can greatly affect tone and volume so I would think most of the drone is coming from the high flow H pipe.
This is one of the better sounding setups. Made me think about switching to an H.
My problem with an X is... they typ sound too raspy. The H sounds better imo, and slightly more tq down low. The X provides more tq / hp at the upper end. Use whatever combo you want, but you have to live with it. One thing tooling around town, or on the hwy for short trips. But on a longer trip, the exhaust can sound tedious. Folks will typ speed up..or slow down a bit, to keep the rpm out of the drone.... 'rpm window'.
Mufflers like the FR500S are tuned for the "OEM" exhaust ( stock catted H) Even Corsa has stated they cannot guarantee their mufflers will be drone free once the stock cats have been replaced with aftermarket O/R or high-flow catted mid sections.. IMHO this would appear to make sense, as once the amount of airflow becomes less restrictive, the exhaust note increases and becomes louder which in turn also increases the sound frequency levels for producing interior resonance drone as well.. My problem with the Borla S-types, is they droned even with the "OEM" catted H still in place and has only gotten louder since adding the Mac O/R pro chamber between 1500-2000 RPM when under load while driving around town and also when sitting at idle in traffic.. Only when not under load, is when the drone isn't nearly as bad and is more tolerable.. Therefore it would seem that by adding a high-flow catted H with Borla S-types isn't going to do much of anything as far as getting rid of drone is concerned when not even the "OEM" catted H made any difference.. However I would like to keep the S-types as I really like the overall sound they provide.. At any rate, it would appear that my only option for getting rid of the interior resonance drone which more than likely is from the Borla S-types, is look into adding mid mounted resonators which actually cancel out the sound frequencies that produce drone such as the Solo performance exhaust system I've been doing research on
