Misfire Or Tune?
RocketcarX
95% of my weight is fuel
Colorado
Barely off topic, but
http://www.aa1car.com/library/ford_tsb_08-7-6.pdf
Per the Ford TSB, OP did it correctly, no? Or am I missing something? Perhaps a bit too much but I don't see too big of an issue. It's been a few years since I did mine but I recall following the Ford TSB and have had no issues since.
I feel it's likely tune related and your tuner should work with you to resolve, or at least verbally assist with troubleshooting. Hopefully you're able to get a log and get some answers.
You do not want anti seize anywhere near the tip of the plug, so if you must coat the smooth part of the plug I would stop applying it 1/4" from the ground strap.
AnotherS197
NW Chicago Suburbs
You do not want anti seize nowhere near the tip of the plug, so if you must coat the smooth part of the plug I would stop applying it 1/4" from the ground strap.
I believe that's about how I did it, maybe a bit closer. Will be swapping plugs shortly here to go to a colder range, so wanted to double check I wasn't missing anything here. Thanks.
EBABlacknChrome
Michigan
Thanks for the input guys. I have been working late and will be for the rest of the week. I will share my finding late tonight. I did some Data logging Sunday afternoon and a few things didn't lot right. The pcm was flashed by ford before I got it. Couldn't find anything online as to what the code meant. I think that may have something to do with it if they didn't account for it..
06monera96
LeShawno
Ontario, Canada
Just so you are aware..
A lot of shops have stopped using ford racing 0 plugs and pretty much any type of plugs of the sort and all switched to Brisk.
The new ford racing plugs 0 degrees or any ford racing plug seem to have changed manufacturing and A LOT of misfires are happening.
Switch from FRPP to Brisk has cleared up a lot of issues shops have been chasing.
