The stock H-pipe/cats have bolts that are pressed in with nuts on the far (engine) side. These are not re-usable for another application, and the UPR x-pipe does not include nuts/bolts to connect it to the stock manifolds so you must purchase some.
Yes, the clamps I was talking about were the stock ones. The x-pipe ships in three pieces, two pipes that connect to the manifolds and then the X itself, which those two pipes slide into and are then clamped on. There are two nuts on these that I recommend replacing since the metal was a bit on the soft side for the amount of torque required to clamp the pipes down.
Perhaps these two images will clear things up:
UPR x-pipe, one side is fitted together but it's clear to see how it's three pieces.
Stock cats with pressed in bolts.
