Flash_of_Yellow
So, I've decided to put in new LCA's and a Panhard with rod ends on both ends. Should be a pretty easy self build. Tube, weld nuts and rod ends. Some custom lathe work to make the bushings, etc.
But, when I was taking the panhard bar out to measure stuff, I found that the panhard was filled with something sounding like sand/gravel. No, it's not road grime that made it's way in. Just wondering if anyone has a good idea what it's there for? I'm thinking it's there for dampening? In which case, if anyone has changed out their panhards for an aftermarket one, do you notice anything that could be associated with the panhard bar vibrating?
