PARTS! PARTS! PARTS! For your GT350!
Discussion in 'Livernois Motorsports' started by Livernois Motorsports, Jun 5, 2017.
  1. Livernois Motorsports
    Livernois Motorsports Livernois Motorsports
    1,377
    Aug 28, 2008
    Dearborn Heights, MI
    This week, we will have all of our products available for your Ford Shelby GT350 Mustang to get you ready for the season!
    Spruce up your engine bay by getting rid of the stock plastic coolant tank with a EvenFlo Coolant Tank! Choose from blank, Livernois Motorsports logo, and the Livernois Motorsports + EvenFlo logos. Custom color and engraving available! Please call for more details and specific pricing.
    For all your GT350 performance parts and installation needs, contact Livernois Motorsports TODAY!
    (313) 561-5500
    [email protected]
    www.livernoismotorsports.com
  2. Livernois Motorsports
    1,377
    Aug 28, 2008
    Looking to add 53hp and 63tq to your 2015 - 2017 Ford Mustang Shelby GT350??
    Start with the Livernois Motorsports MyCalibrator tuner! Increased throttle response, axle and tires size alterations where available, and much more!
    Tuning modifications include:
    Fuel Mapping- The fuel map inside the ECU is able to adjust the air/fuel mix for maximum efficiency and performance in any condition.
    Air/Fuel Management- Air/Fuel management is one of the most important factors in the combustion process. Maintaining a proper Air to Fuel ratio is crucial to getting the most out of your motor and also to prevent damage.
    Rev, Top Speed Limiters and Shifting Characteristics- By dialing in the optimal RPM range and pressures for your transmission to shift at we are extending the life of those components. We also take this opportunity to revise your top speed limiter. These modifications are made to make sure that you are able to have a long-lasting and fun life with your vehicle.
    Timing- Timing is where we control when the combustion event occurs. By revising the moment this happens we are able to increase your vehicle’s performance and efficiency!
    Torque Management- Using our proprietary tuning software we alter when, where and how the computer tries to step in maintain control over your vehicle in a performance setting.
    Tire Size Alterations (Where Available)
    Axle Ratio Alterations (Where Available)
    For you next performance tune, contact Livernois Motorsports TODAY!
    (313) 561-5500
    [email protected]
    https://www.youtube.com/watch?v=IJZnmDR03Xg&feature=youtu.be
  3. Livernois Motorsports
    1,377
    Aug 28, 2008
    Continuing GT350 week with a look at our Powerstorm Billet Steel Main Caps! Available for you 2011 to 2017 Ford 5.0L & 5.2L block.
    Improve the strength of your block by replacing the factory iron caps with Powerstorm 1044 Billet Steel Main Caps. They are similar in shape to the factory caps so they bolt right in! A great option for those looking to crank major power or go racing.
    For your engine build needs, contact Livernois Motorsports TODAY!
    (313) 561-5500
    [email protected]
  4. Livernois Motorsports
    1,377
    Aug 28, 2008
    Get maximum thread engagement in your Voodoo block with the Livernois Motorsports Powerstorm Head Stud Kit!
    Made of 8740 Chrome Moly, broached for use with a hex tool for easy install, and heat treated prior to thread rolling/machining. Available for your 2015 to 2017 5.2L Voodoo block!
    For all your performance parts needs, contact Livernois Motorsports TODAY!
    (313) 561-5500
    [email protected]
  5. Livernois Motorsports
    1,377
    Aug 28, 2008
    Build your Ford Mustang Shelby GT350 from the ground up with a Livernois Motorsports Powerstorm 5.2L Race Block!
    We add our custom iron sleeves, 5 piece billet steel cross-bolted main caps with our Powerstorm main studs. This greatly improves block strength when you want to make 1,000 horsepower!
    For you next short block, contact Livernois Motorsports TODAY!
    (313) 561-5500
    [email protected]
Share This Page
