Quick Fuel Carb, AFR spacer, Ford Racing Steel 18.1 Dampener, Moroso Wireset
RocketcarX
95% of my weight is fuel
Colorado
The carb is a SL-1957E Quick Fuel 600 CFM, zero miles, only used to test fire an engine and removed the same day. The carb is very clean, sorry for the dark pictures. $280 shipped
Ford Racing 18.1 certified dampener for a 5.0/stroker application with removable weight. M-6316-A50, this thing is dirt cheap and brand new, unused $300 shipped
AFR 1" phenolic carb spacer with anti-reversion $30 shipped
Alstar 2" 4 hole taper spacer, brand new, unused $80 shipped
Moroso HEI straight end wire set (listed for BBC/SBC but works with any HEI terminal V8) used for set up and the customer wanted black wires. They need to be wiped down, my tech should have been a little cleaner handling them $55 shipped
ATTACH=full]66928[/ATTACH] ZJNLBjvvQsSEa%1mZ5mmxQ.jpg R3y3cMyQS1WLGP4bL7qjpg.jpg xo9t2YoQQmCx5+fpS79TXg.jpg %lucm5+0R1ql3AhsbWKCNg.jpg
