Gave the BMR double rod end adjustables a try. Had to learn the hard way. Beyond the jam nuts getting loose on me once which was an annoyance the noise is just unreal. Every little sharp bump in the road is a nice thunk in the car. The dash is going to rattle apart some day at this rate.
I suspect that the stock arms may not quite line up properly when I got to put them back in. As in the length may not be exact.
Does anyone have some tips on how to pull the axle back into alignment if I end up having to do that? Only thing I thought of would be to use a screwdriver and pry in the hole or maybe put the adjustable arm back in place and use it to pull the axle in or out.
