crownaviation
http://www.tudyno.com/
I have a vert to begin with but trying to guess on my weight distrubution and cg in stock form. I am attempting to do some suspension work and tuning but here are thoughts..
the vert is more likely heavier in the rear than the coupe. They have extra structure back there along with the motor for the top etc..
So, the cg is likely shifted aft from the coupe to begin with?
Now, to top it all off I have a 6 point bar which would further shift cg aft (toward rear). That and I have the battery in the trunk, a huge 7 gallon intercooler tank in the spare tire cavity and add a little weight when we upgraded the rear. I also run the shaker 1000 subs on the street.
I estimate all the weight I have removed from the front basically is a wash for the increase in weight from the blower and dob manifold
I still need to weigh the car each corner but just as a guess that puts the cg much further aft which will raise my percentage ratio quite a bit.
Thoughts..
This is contrubuting to a anti-squat well below 100% (without changing the instant center). Now, to correct the instant center I will use adjustable lca mounts and keep the upper as long as possible (lower hole) while keeping the pinion angle around -2*. Problem is since the cg is likely way aft, I will need to bring the instant center way back to keep above the normal (or neutral) line. This may bring my IC behind the cg (going off rough numbers and theory). Problem is this will contribute to raising the rear of the car on launch... How can I avoid this or minimize the IC going too far aft chasing the AS ratio?
Going to try to start with about 80/10 in front and keep the rear stiff to see what happens with the tires and go from there
Car is getting a big whipple and will make around 1000 or less on motor alone, getting rid of the nitrous. Also using a auto with tb (converter flashes around 3400 but will likely change with the different blower and no nitrous). Using steeda ultralite lowering springs atm and off the top of my head I do not know what the spring rates are but they seem "soft" and tend to bind with my 27" hoosier qtp
Want this to be a street car primarily but considering a 4 link and coilover
Thoughts..
