S550 seats in S197
Discussion in 'DIY Tech Guides' started by Jkoogler, Mar 12, 2017.
  1. Jkoogler
    Jkoogler forum member
    246
    Nov 14, 2014
    Looks like I'm going to have to bypass the seat module and wire like the 11-14 are shouldn't be to hard just time consuming
  2. Byronj
    Byronj Junior Member
    Jan 18, 2017
    Were you able to hook up the airbag sensors or did you modify that?
  3. Jkoogler
    246
    Nov 14, 2014
    I am looking for a wiring diagram so I can make it work.
  4. CameronPage
    CameronPage forum member
    405
    Jan 4, 2009
    Andalusia, Alabama
    I might have the diagrams where I put them in my 05. Let me look and I'll send them to you. I have a shit load of papers laying around for the 15-16 harness and an 05 harness where I had to tie the doors in and a few more things.
  5. Scott
    Scott Senior Member
    2,266
    Nov 17, 2009
    King City, Ontario, Canada
    I am very much interested in them as well as I have 15+ Ford Racing Leather Recaro seats that need to go in my 08.
  6. Jkoogler
    246
    Nov 14, 2014
    If you could find them that would be awesome. Please let me know
  7. CameronPage
    405
    Jan 4, 2009
    Andalusia, Alabama
    I haven't forgot y'all man. Just been super busy being away. I should be home tomorrow and I'll check it all out
  8. Jkoogler
    246
    Nov 14, 2014
    thank you so much
  9. wystewart
    wystewart Junior Member
    Jan 24, 2016
    are you still looking for 2015 wiring diagrams?
    Can you post some photos of the bracket modifications for mounting into the car?
  10. Jkoogler
    246
    Nov 14, 2014
    I finally figured it out for power to gets seats to move I striped the harness back for the seat and elimated the black box and wired power to the switch and figured out what wire did what. Haven't messed with the heat/cooling yet but the move.
  11. 94_cobra
    94_cobra forum member
    52
    Mar 16, 2017
    Looks killer Man id love to do this
  12. Jkoogler
    246
    Nov 14, 2014
    yes i would love to have the diagram. no i didn't hook the air bag up i just installed a resistor. I stripped all the harness down to the wires and figured that I needed to remove the black box and bypass that all together. So I hooked the power to a 9v battery on the seat side switch and started moving the levers and with using my volt meter i figured out what wire does what. I havent messed with the heating and cooling but I will soon I just wanted poower to move the seats front to back and up and down. As of now the seats move back and forth and up and down.
  13. Jkoogler
    246
    Nov 14, 2014
    Here is a pic I snapped showing what I did. I took a 9v battery and hooked it to the pos and neg. power goes directly to the side seat switch and then run the corresponding wires. I have front and back and seat up and down didn't mess with air for lumbar or for the heating and cooling I ordered a couple hot cold switches so when the come I will install it doesn't seem to hard after taking the seat completely apart to see how it works.
  14. bujeezus
    bujeezus forum member
    2,355
    Aug 31, 2015
    Alabama
    Your definition of hard is very different from mine apparently.
  15. wystewart
    Jan 24, 2016
    I would PM you about 2015 wiring diagrams, but seems I don't have permissions to PM. any ideas?
  16. Jkoogler
    246
    Nov 14, 2014
    Do you have the wiring schmetic?
  17. wystewart
    Jan 24, 2016
    will contact you
  18. wystewart
    Jan 24, 2016
    sorry double post
  19. Jkoogler
    246
    Nov 14, 2014
    Ok to get the seats power to work I had to remove the seat black box and wire the seat movement sections to neg. and pos on the harness that goes to the switch and they work perfect the heating and cooling need to go to relays with switches I am still working on them but got power to them and they fit awesome
  20. wystewart
    Jan 24, 2016
    Any trouble with the air bags and seat occupancy switch wiring?
Share This Page
