School me on drag tire/wheel setups
Discussion in 'Drag Racing Tech Discussion & Timeslips' started by 46addict, Nov 16, 2016.
  1. skaarlaj
    skaarlaj Probie Former Pink Bus Rider
    731
    Nov 16, 2015
    28" for me
  2. stkjock
    stkjock ---- Madmin ---- Staff Member
    35,956
    109
    Jul 10, 2007
    asking tire diameter in a vacuum is a silly endeavor IMHO
  3. fdjizm
    fdjizm Drag Queen
    18,854
    65
    Nov 29, 2009
    NY/NJ
    I've been using those for 2 years on my front 15x4's, no issues.
    I run JegStars with a 3/8 spacer and had to shave my caliper a bit.
  4. jam07GT
    jam07GT forum member
    57
    Jun 6, 2016
    x2
    Right on. Race Star 15x10, 7.25 bs. Like said above, you need to have the sway bar relocation bracket, or a BMR sway bar, which is what I have. Stock brakes. Just have to cut the "tabs" off the stock mounting point. I have same wheel, 15x3.75, 1.5 bs fronts. I have the MT front tires, the ridiculously expensive ones (Sportsman SR, 28x6). I really wanted a 28" front that was also a radial tire.
    For rears, 275-60-15 MT drag radial SS. About 28" tall. I have 4.10s/auto. I have run the major drag radials (NITTO, BFG) over the years and the MT are by far the best traction for the track, imo. I run them at 22 PSI racing. Just haze them for the burnout.
  5. lindertw
    lindertw forum member
    865
    Jun 23, 2011
    NoVA
    bias ply rear tire will be more forgiving with your manual trans, but it's your money...
    I have M/T et street bias ply tires, 26" diameter (low power n/a car with 4.56 gears) on 15x8 weld rts wheels - no spacers, no grinding, mcgard lug nuts. The tires are have been discontinued by M/T, but Hoosier QTP are similar and folks run them with great results. When mine wear out I'll go with a full slick.
    With the right suspension setup and tire you can launch hard and get the most ET out of the car. Good luck!
  6. jam07GT
    57
    Jun 6, 2016
    I totally agree on this. That's why I bought an auto car. I wanted to run drag radials and drive it to the track. I tried every drag radial on my 4 speed Chevelle and nothing worked. Every once in a while I would get a clean pass in, but very rare, and I had a two step, etc. Bias ply for stick cars is the way to go.
  7. 46addict
    46addict 13726548
    1,236
    Aug 25, 2016
    Lawrenceville, GA
    Did you run inner tubes with those bias plys? I see some people on the forums running without tubes, and some people do.
  8. lindertw
    865
    Jun 23, 2011
    NoVA
    no tubes on my setup. I ran 15psi cold at the track, and 25psi when driving around town.
    I had them mounted with permatex high tack to keep them in place on the rim
  9. djniknala
    djniknala forum member
    54
    Apr 21, 2012
    I did the same(using high tack) on 15" dark stars with Hoosier stiff sidewalk slick at 14psi cold with no tubes. I marked the rim and tires and they never spun in relation to each other. I had 50 plus launches on these with over 20 being at 7k rpm in a '12 GT NA 5.0. All but 3 of those launches were 1.46-1.49.
  10. casper gt
    casper gt forum member
    121
    Jan 20, 2012
    Creighton Pa
    Its always best to check the rules at the tracks you run at before you decide on the tube/no tube thing.
    Some tracks don't care (actually most) if you have tubes or not but some will not let you run a tube type tire with no tube.
    Just an FYI thing.
  11. 46addict
    46addict 13726548
    1,236
    Aug 25, 2016
    Lawrenceville, GA
    50 launches sounds like a lot. Do they start losing grip after that?
    Thanks everyone for the replies so far. Been a big help.
  12. djniknala
    54
    Apr 21, 2012
    I didn't do huge burnouts with them but they hadn't shown any signs of slowing down.
Share This Page
