sportinawoody
selling off my project. paypal i s ok if you pay the fees . will consider trades for s197 parts. here goes
1985 asc mclaren hard top 1 of 150 made, by the vin it was definitely one of the first 50 and probably one of the first 30 but impossible to tell which. car is STRAIGHT and SOLID. been in my garage for years. that means no panels rusted out for those of you wanting to ask. no history on title, last registered mileage was 88,000 . will supply a carfax . still have some of the factory parts that will go with it but it has an rs front end instead of the asc correct one.
1500 non negotiable. you need to supply a rear and wheels to roll it as its on jack stands. serious inquires can pm me your number and ill fill in the blanks for you.
autometer ultralite 5in tach w/ shift lite 125
autometer ultralite fuel level for 79 -86 30
autometer ultralite fuel pressure for carb non electric 30
autometer ultralite oil temp 30
autometer ultralite oil pressure 30
autometer ultralite ammeter 30
autometer ultralite coolant temp 30
or ill do 275 for all 7 SOLD
aluminum battery box from cartech 60
adjustable clutch cable and quadrant and fire wall adjuster 65
holley blue fuel pump 40 SOLD
torque box reinforcements ( lower ) 25
rearend loaded, 500.00 firm
NEW sperical bushings 50 SOLD
NEW IN BOX upr front coilover kit ,
springs are drag rate 14" 150lb. for 3000 to 3300 lb car 160 shipped
pics : http://i163.photobucket.com/albums/t293/sportinawoody
306 , billet 4 bolt mains, block half poured, lunati crankshaft, race cut by the crankshaft specialist, 40 some odd pounds, eagle rods, ross pistons, coated bearings, new cam bearings, total seal stainless gapless file fit rings filed for boost, arp head studs, arp main studs, arp oil pump driveshaft, melling hv68 oil pump milodon windage tray , pickup ,and pan all modified to fit this setup w/ the billet mains, 18:1 sfi ford racing damper, 0 miles never been run. 3500.00 obo the crank is 3000 alone . ive got 5800 in this setup so someones gonna get a really good deal on a bulletproof bottom end. keep them offers coming, but please be prepared to follow through before you make an offer.
mallory comp 9000 mechanical advance distributor for carb, 150
msd 6al w/ 6600 chip 125.00 or will do 250.00 with mallory distributor w/ ford racing wires and accel coil as a package
pro comp electric water pump w/ plate and water neck 100 SOLD !!!!
ford motorsport tall aluminum valve covers 65
crane 1.6 7/16" roller rockers w/ locks and hardened push rods stock length 125SOLD
t5 tranny short shaft to fit 79-93 400
ram 900 series clutch 100 miles good for 600rwhp with billet flywheel 350
brand new sfi flexplate 40
poly strut bushings 20
super victor w/ matching fuelrails and fabbed elbow on nos plate brand new no box 450 SOLD !!!
aluminum driveshaft 150 SOLD !!!
80 mm bbk throttle body 150 SOLD!!!!
trick flow engine gasket set w/ loc wire head gaskets 100
new ford racing roller lifter set out of box, soaking in 10-30 oil since removed from plastic 75 SOLD!!!
