Shark Bite fittings
Discussion in 'Home Improvement' started by Dad, May 29, 2018.
  1. Dad
    Dad forum member
    407
    19
    Sep 28, 2016
    SW KY
    Anybody have experience with these? I have a copper ice maker line that I need to repair and the guy at Lowe's said they are the best thing ever. I have not connected it yet. I couldn't get the copper line to push into the coupler. Do I need to remove the little sleeve thingy from the coupler? This is what I bought.
    https://www.lowes.com/pd/SharkBite-...-Connect-dia-Coupling-Push-Fitting/1000192625
    Maybe I need the 5/16 rather than the 1/4?
  2. mustang02
    mustang02 forum member
    208
    Apr 18, 2012
    They are a quick and easy fix so you don't need the sweat the pipe.
    Don't remove anything. Just slide the pipe in and it will eventually stop. Maybe you have the wrong size?
    Sent from my Pixel 2 XL using Tapatalk
  3. flipper
    flipper Junior Member
    25
    Nov 16, 2017
    I’ve used them...best thing since a plumbers crack...oh, did I say that? After you cut the copper pipe, de-burr before sliding on the Sharkbite. Great product...
  4. jhunt47
    jhunt47 forum member
    116
    Aug 20, 2016
    I’ve used the myself very good products.
  5. pass1over
    pass1over I like it LOW
    38
    857
    Oct 9, 2011
    Trenton, FL
    shark bites are great, we use them a lot at our shop. All advice given above is good advice. Deburr, cut flush, push till it stops.
  6. Slick4.6
    Slick4.6 Junior Member
    49
    Sep 12, 2017
    Central NJ
    Never had an issue with any I’ve used.
  7. Shotokan1509
    Shotokan1509 forum member
    3,841
    Aug 13, 2008
    CT
    I used for hotwater heater because I may still move it slightly, haven't had any issues
  8. WJBertrand
    WJBertrand forum member
    370
    Dec 11, 2013
    No, don't remove that little sleeve, it's part of the fixing mechanism. I just used some of these to connect an RO water system under my sink. I used polyethylene tubing but it should work fine on the same OD (in my case 1/4") copper lines just as well.
