Shooting From The Hip: Rear Spring Rate
Discussion in '2005+ Ford Mustang v6 4.0L Tech' started by Benwhite911, May 11, 2017.
  1. Benwhite911
    Benwhite911 V6'ing & Dealing With It
    128
    Nov 27, 2016
    Cape Coral, FL
    I've been monkey'ing around with the suspension on my 05 V6 now for about 2 years. I originally started because the shocks and struts were shot and needed replacing. So I looking into lowing the car, and that's where my interest took off. Now I'm going to jump ahead to my current set up and then ask my question.
    Shocks Struts: Strange Engineering 10 Way Adjustable
    Front Springs: H&R Super Sport Springs
    Rear Springs: No Name Generic
    Front Swaybar: 35mm Granatelli
    Rear Swaybar: 25mm Granatelli
    Upgraded Control Arms both Front and Rear.
    So here is what I'm looking to do. I bought the Steeda Rear Ride Height Adjuster Kit and I want to install a set of rear coilover springs. The rate I'm toying around with is 400 lb rate. Does this sound link an awesome or an absurd idea?
  2. 46addict
    46addict 13726548
    1,301
    Aug 25, 2016
    Lawrenceville, GA
    400# in the rear is a lot especially with your sway bar size. I imagine you will need huge rear tires to support the extra wheel rate. I would choose the tire compound & size you're going to run and set up the car around the tires. A properly setup suspension and brakes can easily overpower most street tires so there's no point in building those components if the tires aren't up to the task.
    FWIW I have a 335lb spring waiting to be installed and Vorshlag (among other track junkies) didn't recommend going higher for a street car. I am still on the 21mm (or is it 19?) stock swaybar in the rear.
  3. Benwhite911
    128
    Nov 27, 2016
    Cape Coral, FL
    Thanks for your insight. I wouldn't mind getting rid of the rear swaybar. I never noticed a change when I installed it.
  4. TexasBlownV8
    TexasBlownV8 Formerly TexasBlownV6
    4,851
    Apr 4, 2008
    Central Texas
    Most V6's came without a rear sway. I could tell a little difference without it. Not sure how it would feel without both the front and rear sways; would it be dangerous on the street?
  5. Benwhite911
    128
    Nov 27, 2016
    Cape Coral, FL
    But what about the 400 lb rate rear springs? What is your opinion on that?
  6. pass1over
    pass1over I like it LOW
    37
    815
    Oct 9, 2011
    Trenton, FL
    i've got BC Racing coils on my car, they come with 7k front and 5k rear, which converts to 392# front and 280# rear.
    Had an 8k in the rear for awhile, which is 448#, it was SUPER stiff, I felt every single bump, crack and divot in the road. Put the 5k back in there and it's tolerable.
Share This Page
