So I just slapped on a Snake Bite. I should be reading 17psi and instead am only showing 10psi. I talked with Steigmeier yesterday and they gave me a couple ideas. But they all failed.
Here is what I do know...
Upon inspecting the set up last night I noticed a line that came from the EGR valve on the passenger side over to the bypass valve on the driver side was disconnected. I connected it and was a little relieved. Jumped in the car and that didn't fix the problem.
The other setup difference that I have is I am not running the rear evap system. Is this connected to the blower in anyway that would allow boost to leak.
Looking at the diagram is shows that there is a PURGE valve. If this purge valve opens will it cause the air to just escape since I have nothing trapping it in the rear of the vehicle? I just don't know how it all works together.
Anyways, any ideas...
