swflastang05's build thread
Discussion in 'Mustang Chit Chat' started by swflastang05, Jun 8, 2014.
  1. swflastang05
    swflastang05 Back for More
    1,849
    Dec 21, 2013
    SWFL
    Nah, my car is way too slow to be a race car lol
    Thanks Scott! The new steering wheel is a bit smaller than the OEM, it takes a little getting used to, also you can feel all the bumps in the road a lot more sensitive somehow. I ran over a couple reflectors in the road this afternoon while changing lanes and was like what the hell was that! Felt like I hit something.
    I resolved the belt getting eaten issue. Ended up deleting 3 more idler pulleys, basically ended up with a 48" belt routed like this:
    [​IMG]
    I went for about a 5 mile test drive and the belt stayed on. Checked everything real close and didn't see any obvious signs of unusual wear or other issue so hopefully it stays fixed. I suspect the issue was related to the AC delete bracket and pulley I was running before, in any case it's gone now along with 2 other pulleys and all seems good. Now to address the damn tranny..
  2. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    And here we go again!! FB wanted me to send the convertor back first, just to make 100% sure there's still not an issue with that before I send the whole tranny back. Well I am getting quicker with all the practice, only took me about an hour to get it out this time..
    [​IMG]
    [​IMG]
    [​IMG]
  3. travelers
    travelers Senior Member
    2,580
    9
    Apr 6, 2007
    Eastern Pa
    Don't they test the converter before they send it out?
  4. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    I would hope so but you just never know for sure, heck they didn't even paint it this time so I know they were in a hurry, anything is possible. I wouldn't be surprised at all of it was bad either since there was some nice glitter in the fluid again when I drained it before shipping. FB sends the convertors out to a third party, they don't do them in house. Last time it came in box labeled "TCS - Torque Convertor Store" out of Arizona. Not sure if that's who makes them or not though. I am glad I have an FB tranny and convertor, at the moment, otherwise there would be a ton of finger pointing. One thing is for sure, I never should have sent it back to be loosened while my motor was out, everything worked perfectly before that.
  5. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    I spoke with FB again today, Fred wants me to go ahead and send the whole tranny back so he can go through everything and make sure it's 100% right and also freshen it up while he's in there. At least when I get it back it will be brand new again. In the meantime I went ahead and prepped it for transport back to NY after work today. After draining as much fluid as possible I bolted the wooden ends on and loaded it back into the barrel. For some reason sending my tranny cross country in a barrel is kind of funny to me lol.
    [​IMG]
    [​IMG]
    [​IMG]
    Fred promised to make my job a priority and get it in and out ASAP, we shall see. In any case after I get it back and installed I will essentially have a brand new motor and brand new tranny so 2018 will be a great year for sure!
    slackinoff likes this.
  6. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    Tranny shipped out on the 4th, should arrive at FB on the 8th, as long as the frigin' blizzard doesn't slow it down lol. In the meantime I finally did a little project that I've wanted to do for a while, finally installed NHRA legal 3" wheel studs on the front end. I was going to simply order the studs and press them in and out of my hubs but by the time you buy the stud kit and two spindle nuts you'd be in nearly $150, for another $100 I got the whole FRPP hub assembly with the ARP 3" studs pre-installed and new bearings, etc.
    Here's a few pics, no mind bending tech or anything just a few pics:
    Before:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    One note I'll mention the spindle nuts are disposable, where you're only supposed to use them once then if you ever need to loosen them they're considered junk. I was aware of this going into the job but was not aware that Ford recently changed the design of the nuts. I searched all over trying to find the original type thinking the new style was wrong, but it's not. Original on right, new style on left. Torque to 221 lb ft for 07 and earlier cars. 08 and up I think it's 250 lb ft.
    [​IMG]
    And Done:
    [​IMG]
  7. travelers
    2,580
    9
    Apr 6, 2007
    Eastern Pa
    That's what I did with mine this summer. When I got the new nuts they were the older ones on your right.
  8. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    Well verdict is in, FB tore down my tranny today and found the input shaft was bent, and displaced the bronze pump bushing and lock up seals, resulting in all the lock up pressure bleeding out, that and the pump was tore up pretty badly too. We think this probably happened during my previous engine failure last year when the block cracked so bad it looked like #6 - 8 cylinders were ready to detach from the rest of the motor. So a new input shaft, front drum and pump are going in, as well as freshening up the rest of the tranny. The torque convertor is getting redone again also, and upgrading to an improved design bottom plate. If all goes well everything should ship back out to me this week yet, wow that sure would be nice! In any case hats off to FB for jumping right on it when they received my tranny yesterday. Heck he said they're still trying to recover from the bomb cyclone storm thing that hit them last week, said they had a hell of a time just trying to get the drum off the truck when it arrived due to all the snow!
  9. travelers
    2,580
    9
    Apr 6, 2007
    Eastern Pa
    Wow that must have been some kind of (what ever) that did that kind of damage to the block and the trans. That's some good customer service to get it knocked out that quick.
  10. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    Detonation was the verdict on that failure, took out both my engine and tranny! Holy shit! Never would have thought that was possible at my power level..
  11. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    Needless to say a 300M input shaft is being installed this time.
  12. 46addict
    46addict 13726548
    1,361
    10
    Aug 25, 2016
    Lawrenceville, GA
    Do the spindle nuts have TTY threads? I didn't know they were considered disposable.
  13. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    I have no idea why they can only be used once, maybe it's something to do with that. I know once you torque them to spec at 221 lb ft if you touch them again they're done.
  14. swflastang05
    1,849
    Dec 21, 2013
    SWFL
    My transmission finally shipped out on Friday, there was a delay getting the new billet input shaft but it should arrive on Wednesday next week. I was previously planning to go to the track tomorrow for run day Sunday, but that of course will not be happening now. In any case I was able to knock out another project while my car is up in the air that I've been wanting to do for a while, upgrade my fuel feed line from -8an to -10an. That -10an is one big ass line! Here's a pic right next to the -8an return.
    [​IMG]
    [​IMG]
    I'm just waiting for the fitting that connects to the top of my Fore hat and the -10an line. I eyeballed the old fitting and it "looked" like -8an where it screwed into the hat, of course when I went to install the new fitting it turned out the opening is -10an, which is great but I had to order another fitting b/c I was too lazy to actually pull the old one before I ordered the new one! It was freaking cold that night though lol.
  15. Heaten m90
    Heaten m90 forum member
    272
    Jun 3, 2017
    I don’t understand why they can’t just put what size it is on the fitting.... like wtf
  16. fordave
    fordave dna (ford)
    69
    Jun 26, 2017
    ft myers fl
    Nice build, we definitely should get together, who did your coatings
Share This Page
