Synchronizer Replacement
RolloTomassi
Hey gents, got any suggestions on how to replace the 5th gear synchro on an 06' v6?
It's got 110k miles on the original clutch/flywheel and is only now having difficulty shifting into 5th cleanly. It's livable but certainly not ideal.
I had the same problem on my GT but it was under warranty then so I didn't ask any questions. But I'm afraid to take it to the stealership because I know I wont get out of there without a receipt for a grand.
Should I just live with it? Or when it gets too bad just bite the bullet and replace the clutch aswell while I'm at it?
Kuro!
Banned
Austin, TX
Just buy a new trans.
I'm pulling my T5 out of my 07 within the next month hopefully. It's got 40k miles, You can have it if you just pay for shipping.
chad05gt
Lake Charles, La
Just buy a new TR6060 trans.
Fixt!
And be done with it... 3650 isnt worth fixing.
fdjizm
Drag Queen
NY/NJ
I had my synchros replaced by the dealer two years ago, If I was out of warranty I would just pick up a 6060 instead of spending money fixing the 3650, I think you can grab a 3650 on ebay for like 500 bucks.
Kuro!
Banned
Austin, TX
The TR3650 is fine. Aside from user error, you'd be hard pressed to fuck one up N/A.
The 6060 is obviously a much better piece, but also 6x the price in some instances.
chad05gt
Lake Charles, La
Went through 3 before TR6060, launch hard, powershift, and drive daily... it wont take the abuse.
Threw away time and money b4 making the right choice. Its not the bottom line in $, but VALUE for $.
Just trying to save op time AND $.
Kuro!
Banned
Austin, TX
I'd place launching and powershifting under user related issues. If you don't launch on it and avoided power shifting it you can make a 3650 last a good long life.
Now you seem to be drag racing, I don't see the OP drag racing a V6 with 100k on the clock.
up_yours_7
My second gear is almost totally shot and I just replaced the clutch less than 10k miles ago. Isn't the 6060 a six speed?
RolloTomassi
So tranny swap huh? Is that the general consensus?
If so, how many hours work? How much would it run me?
Would I be better off replacing it with a better trans?
up_yours_7
I'm not a big fan of six speeds so I would do a gt trans they are way smooth
fdjizm
Drag Queen
NY/NJ
If you have a v6 i'm not sure a GT tranny would be a good idea, now i'm not 100% on this but i'm thinking the whole gearbox is geared too low for the v6.
cemetery gates
Just find a new T5. I swapped in a TR3650 into my v6 and I only did it because I'm gonna be running more power then the stock T5 can take; it is not worth it for a stock v6. The gearing is a little off(too low) but not bad, nothing some 3.73's or 4.10's wont fix. I have my stock T5 laying around with 30k miles on it, PM if interested!
