VTXFrank
Obama SUCKS!
So when jewc75 mentioned in a thread he was selling his MGW shifter for the MT82 trans, with heat shield, I decided to jump on it. I was second in line and was quite happy when the first person dropped off the deal.
I got the box VERY quickly and since I wasn't having too good of a day on Thursday, decided to watch the install videos and install it the next day, Friday.
Now I've never really had any issues out of my stock shifter. I still think it's one of the best ones Ford has put in a Mustang GT, but I have always put short shifters in my cars and wanted to get rid of the slop in the OEM shifter.
So yesterday morning, I set to work. Getting the install done took me longer than I thought it would since I was in my driveway on jackstands. Having big hands doesn't help either, so it was a bit of a PITA. I used blue locktite on every single nut and bolt. About three hours after beginning, I was done and ready to test drive.
I absolutely LOVE the shifter. It's precise, well balanced and the throw reduction is perfect. It "snicks" into each gear and gear selection is instant and without the drama of typical downshifts with the OEM unit. No more selecting the wrong gear when downshifting. From speed-shifting to full on power shifts, it gets into each gear with little fanfare and a precise engagement.
Initially, I thought the throw reduction wasn't going to be enough, but that I would be happy with any reduction in throw and most important, a more stable, solid feeling shifter. But that 20% reduction in throw is quite noticeable and VERY tight while remaining smooth and positive. Reverse works great as does my rear camera. Nothing you replace has anything to do with the reverse lights or rear camera activation.
Now this shifter is noisier than the OEM unit. It isn't the shifter that noisier, rather, it's the new rigidity of the shifter transmitting more noise. This will likely be largely cured when I get some Dynamat or like material for sound deadening.
Thanks to jewc75 for the shifter!
