Installing hot rods on my 05 gt, just got the drivers camshaft in. Doing the half-turn at a time method to get the cam back in. Was a pain doing all the caps slowely with that much pressure. Could only get the first three caps on and tighten them a little at a time till 4 And 5 could go on then go in order slowely. Does that seen right? I had the crank at the 12, cylinder 5 was coming up on the exhaust valve. Is there a position that doesn't put as much pressure on it that I can do on the passenger side? My second question is timing g chain slack. I used a wedge tool for the install. I noticed on the straight side of the timing chain (the side without the tensioner) has some slack. I can rotate the cam counter clockwise and I can see the tensioner come out and the slack is gone. However the spring keep wanting to rotate the cam clockwise and put a little slack on the other side. Will this be fine on startup? I figure it's happening cause there's no oil pressure to push the tensioner out right? All my timing marks are right on the phaser, just can't see the crank
