Just swapped my 275 fronts / 285 rears for my 235 Motivo rain tires I use in the winter.
The 275's appear to have aprx a 9.75" wide tread. The 285's have aprx 10" of tread.
IF I have the story correct, the tire size, like '285' on the prescribed... '10" measuring width' rim is supposed to sorta equal the outer sidewall to inner sidewall dimension...aka section width ?
Both the 275's + 285's are on 10" wide rims. Interesting enough, both have 3 wide rain grooves. (Both are Nitto NT-555's). The rain grooves on the 275's however are slightly narrower vs the 285's. I can't quite get my index finger to lay flat on the 275 grooves, but on the 285's, index finger drops right in.
It appears at 1st glance that the extra 1/4" of total tread width on the 285's.... just got mostly negated by the wider rain grooves.
Whether a tire is mounted on it's min or max recommended width, it appears that the actual tread on the road (with 900+ lbs applied) stays much the same. (and 32 psi used in both extremes).
I noticed some of these different tire brands run wider than other brands. Some are wider, even with the same brand, but different model within the same brand, yet both are... '305', etc.
My 235 Nitto Motivo's have wider treads and bulge more, vs the oem Pirellis, also in a 235-50-18. And both use a 7.5" wide ..'measuring width' for the wheel rim width. And I'm using oem 8" wide rims.
Some of these 305 tires have section widths almost a 1/2" wider than '305'... like 12.4" . 305mm = 12.008".
Are these different brands using.... loose guidelines ?
