NO IT IS NOT, the 3 link pivots at the upper rear which makes a huge difference.
You missed the point I was trying to make. Once you consider the TA's beam to be no different from a diff housing with an extremely long pinion snout, and that no different from a 3rd link eye at the top of the diff housing, the geometry constructions are more similar than they are different. And it's the geometry that locates the SVIC, which in turn defines the geometric portion of load transfer.
For every FT/LB of torque applied at the tyre footprint equals the same amount of thrust at the axle centreline.
This thrust needs to be transferred into the frame to accelerate the car[which is what a 3 link or 4 link does]
It's what any suspension linkage for a driven axle has to do . . .
The 3 link [when viewed from the side] has an Instant centre which is the theoretical point of acceleration. [the same goes for the 4 link, the thrust is shared between the upper and lower links]
When pinion torque reaction is factored into the equation, the compression loads are less on the upper and increased on the lower links .Which is why a single upper is more than enough.
The single upper goes tensile. But yes, a single upper is sufficient. In most cases, the tensile load on the upper is of generally similar magnitude to the compressive load on either lower (taken individually).
What GM did with the 3rd gen is place the Links directly in front of the axle centreline so it controls All the thrust loads. These links pivot so any rotational torque is controlled by the torque arm [the torque arm doesn't control any thrust loads at the front pivot, only vertical loads]
Actually the LCAs on the 3rd and 4th gen F-bodies picked up below the axle much like they do on the S197. This picture is from a 4th gen, but I have a 9-bolt axle holding up the back end of some non-GM car that I'm certain came out of a 3rd gen that picks up the LCAs in the same place (didn't the 9-bolt come from your part of the globe?).
The MK1 Lotus Cortina is similar to the GM 3rd Gen by having the outer Links directly in front of the axle centreline, but instead of a Torque arm they had a Triangulated link under the diff housing [not needing a panhard or watts]
Lotus calculated that brake torque through the axle was far greater than pinion torque reaction so having the A Frame underneath was under tension during braking and stronger [Plus the roll centre was lower]
Directly in front of the axle would be a unique case. Meaning that you can't use a mathematical singularity like that to prove the general case. The wishbone would have to run backward from the axle in order to be in tension during forward acceleration. Keep in mind that the axle torque
reaction is trying to make the pinion go nose up, so a forward-running wishbone would still have to go compressive to push it back down. Remember, it's not the LCAs trying to pull the pinion into a nose-up condition.
FWIW, I've seen pictures of this arrangement on fairly high-HP cars. Ground clearance, diff housing strength, and single-shear use of that big bolt would be direct design concerns. Exhaust routing and tube size would likely be affected.
With the griggs TA with a fixed front pivot, [pivoting on a longer arc] it would be better off with the outer links removed[that pivot on a shorter arc] and then add 2 triangulated arms from the front pivot back to the outer axle tubes [truck arm style]
The Griggs has to use a compliant front pivot, else the suspension becomes over-constrained and will bind. Like you said, if the Griggs TA front pivot was truly fixed, they might as well do their own version of Hotrods to Hell's truckarm.
The reason I'm sceptical, Is I fully understand how a Torque Arm functions [I've designed and fabricated racecar suspension before] I don't really need to spend hours making an international phone call to listen to somebody justifying their opinion.
All you need to do is accept the idea that Griggs incorporated enough compliance in their TA's front pivot design to accommodate plunge and rotations. It's the only way it can work without bending and fatigue-failing the brackets and other structure. I realize that taking out as much compliance as possible is the general approach to race car suspension design, but you simply can't do that with the Griggs TA design. (well, I suppose you could if you made the LCA bushings even softer than OE, but that'd be an even worse way to avoid 'bind'). Griggs can get away with this compliance because it doesn't affect axle steer enough to matter, and pinion angle only a little (due to the length of the TA).
Norm
