TR6060 & Spec clutch
Status
Not open for further replies.
JDCoon
Jena, LA
Here is a used tr6060 with ford racing shifter with 14k miles on it and a Spec twin disc clutch and flywheel with 8k miles on it. Both removed from a 09 gt500. Asking 2750 OBO. Can ship anywhere in U.S. Can email or text more pics if needed.
JD please repost the pics using a different host site. Nothing shows up
JDCoon
Jena, LA
mrt2you
new berlin
to help the OP.
the clutch should be a 26 spline disc. the 3650, stock gt trans for 3v cars, that is probably in your car is 10 spline so it won't work with your 3650 trans.
the ENTIRE assembly, trans, clutch and flywheel will bolt in your car. as others posted you will need, not listed, a 6060 trans cross member to finish the install.
Status
