TSB Lists for 05-07 Mustang GT 4.6L.
tmcolegr
It's All About the Build
Central, FL
TSB 10-3-8 GT 500 Clutch Drag - Revised
  • TSB 10-3-8.pdf
raverjames
Beer Advocate
Richmond, VA
This article supersedes TSB 9-9-6 to update the Service Procedure.
Anyone else suffering from this issue, but the dealer wont fix it? My car always grinds going into 3rd gear when it is cold, yet the dealer tells me that is normal. I had this repaired one time, but it came back. I have had many problems lately, but the dealer can't seem to find anything. If this thing wasn't under warranty, I would tear into it myself.
tmcolegr
Central, FL
Take a copy of the TSB in hand to another dealer.
tmcolegr
Central, FL
TSB 10-4-13 Convertible Top - Headliner Pulled Out From #1 Bow
  • TSB 10-4-13.pdf
tmcolegr
Central, FL
Luggage compartment lid solenoid stuck open
  • tsb10-05-09.pdf
area5179
Do you guys know this one?>
M/T - Buzzing/Oil Canning Noises
TSB 08-2-10
02/04/08
4.6L MANUAL TRANSMISSION - SEPARATOR PLATE
BUZZ - BUILT BEFORE 12113/2007
FORD:
2005-2008 Mustang
ISSUE
Some 2005-2008 Mustang vehicles built before 12/13/2007 and equipped with a 4.6L engine and manual transmission, may exhibit an oil-canning or exhaust rattle/buzz around 2000 - 2500 RPM during the first few minutes of driving after a cold start. The sound goes away after the car warms up.
ACTION
The concern may be caused by the separator plate, between the rear face of the block and the transmission housing, vibrating and/or contacting the flywheel. Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1.
Remove transmission per Workshop Manual (WSM), Section 308-03B.
2.
Pry separator plate from rear face of block alignment dowels, slide out from between block and flywheel, and replace with new service part.
3.
Install transmission per WSM, Section 308-03B.
I just got busted with this tsb. got new rear brakes and clutch as well
. i am now $1500 poorer.
area5179
sorry about that. Meant to say I have this tsb issue. just got my GT back from the shop. It's almost like driving a brand new car. The clutch takes so little effort to engage. When I first stepped on the clutch it was so light I though it was broken!
tmcolegr
Central, FL
TSB 08-3-4
  • RATTLE/BUZZ/VIBRATION - TRANSMISSION CROSS-MEMBER EXHAUST MOUNT - BUILT BEFORE 12/3/2007
This is an old TSB but somehow didn't make the thread
  • tsb08-03-04.pdf
tmcolegr
Central, FL
Tsb
07-16-7
  • exterior door handle not flush in the closed position
  • tsb07-16-07.pdf
tmcolegr
Central, FL
Is there a TSB for a/c issues with the 2010 GT's?
TSB 09-16-1
  • A/C LACK OF COOLING - 4.6L/5.4L V8 ENGINES ONLY
Publication Date: July 30, 2009
FORD:
2010 Mustang
ISSUE:
Some 2010 Mustang vehicles built prior to 6/22/2009 and equipped with a 4.6L/5.4L V8 engine may exhibit a lack of A/C cooling. A calibration is available to correct A/C clutch cycling that may occur under a low refrigerant charge condition.
ACTION:
SERVICE PROCEDURE
  1. Follow Workshop Manual (WSM), Section 412-00 to diagnose and correct any A/C lack of cooling before continuing with this procedure.
  2. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 61.16 and higher or 62.04 and higher. This new calibration is not included in the VCM 2009.7 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATIONDESCRIPTIONTIME091601A2010 Mustang 4.6L/5.4L: Reprogram The PCM.0.3 Hr.
2kanchoo
Is there a tsb for water leaking into the compartment on the passenger side, behind the removable panel? I couldn't find it in the lists. (could be blind too) I've got a 2006, and I noticed after rain the other day water was coming out of that panel and the passenger side carpet was wet.
Crappy Blackberry Pics
calimustang
Central FL
mines 2008, got grinding noise at 3rd gear during deceleration... is there an TSB for newer S197's?
05-8-8
Growl/grinding Noise In 2nd Or 3rd Gear During Deceleration - Tr3650 Manual Transmission - Vehicles Built Before 1/15/2005
