"We're out of roast beef..."
SoundGuyDave
This Space For Rent
So, my enduro co-driver Joe and I went racing this weekend, just to knock the rust off…
I wrecked a couple of years ago, and work got in the way of getting on track between then and now. Joe, on the other hand, wrecked about a year ago, and has been rebuilding his car ever since. It’s still not quite ready, but it’s getting close. We both had the bug, and found a weekend that worked, so we decided to take my half-patched up hooptie out and run a race weekend with NASA At Autobahn in Joliet, IL. We did a “supersize” team entry, which allowed EITHER of us to drive in both sprint racing and Time Trials. This is a GREAT way to get a lot of track time in a competition environment for minimum dollars, and NASA puts on a fantastic and organized “show.”
Without a current dyno sheet, and being cheap, we went with scrub Pirelli P-Zero non-DOT slicks and declared as American Iron Extreme for the race group, and TTU for Time Trials. Now most of you know about my car, and it’s a fairly conservative build, all focused on suspension. 310HP, 342TQ, 3350lbs, so not a pavement-tearing monster by any means, but it gets around the track pretty well for what it is. American Iron Extreme and TTU are “no dyno required” UNLIMITED classes, so we were “competing” against absolutely insane builds, like 1000+HP Viper ACRs, high-downforce Lotus Elise, and 800+HP S550 Mustangs… We were going to get creamed, but we’d have an absolute ball doing it.
We had a few details to handle prepping the car, like replacing a seat, harness and window net for safety compliance, a couple of post-wreck fixes like swapping a radiator, and basic maintenance (oil change, coolant flush to distilled water and Water Wetter, plus a basic oil change). No big deal, and we gave ourselves a day and a half to do it. Simple, right? Right! Another buddy, John, had my trunk lid and was fabricating underside mounts and reinforcements for the new wing I bought, so we’d just bolt that on at the track.
Things went wrong very quickly in the prep phase, when I discovered that the mounting point width on a Sparco Pro ADV is actually wider than the points on a Circuit II. Okay, I had replacement side mount brackets and a replacement slider on hand, so in they went. With some drilling of carbon-hardened steel…. Ugh. Finally got that done, and the belts and net installed, and knocked out the maintenance. Then we left to grab a trailer. Joe’s trailer has the husk of his old car still sitting on it, and mine has expired tags (VERY expensive in IL), so we arranged a U-Haul car carrier rental and ran up to grab it. BUT, it turns out that the 7-pin trailer socket on Joe’s truck has a duff pin, so we couldn’t get a left turn signal to the trailer, and U-Haul refused to release the trailer without it… No good. By the time we played games with this, the track was open on Friday for early arrivals, so we shot over there, and went looking for a trailer to “borrow” to get the car to the track. Found one, hitched up, sent U-Haul a “you’re number one!” and grabbed the Hooptie.
Set up a nice little paddock area, and grabbed the trunk lid. John got all the fab work done, but just didn’t have time to actually mount the wing itself on the uprights. Something about “walking towards an $1800 piece of carbon fiber with a drill in my hand not going to happen,” so he’d let me do the nerve-wracking part. Fine, no prob on my end, except that it was getting dark by that point, so screw it, we’ll run the race-group practice session without the wing (never had one so wouldn’t miss it) on Saturday, and slap the wing on during lunch. Piece of cake. Saturday was my day to race, and Joe’s to run TT, so we got to the track nice and early (7:00AM?!?) to make the meetings, get the tires mounted, and flush the brakes. We wanted to do that Friday, but it was just too late after dealing with U-Haul, so… $202 later for four mount/balance we had scrub Pirellis on the car, with fresh fluid, and were good to go. I went out in the Practice session, and on lap 2, with the tires JUST starting to come up to temp, the seat slider slipped, and I found myself in the back seat, pedals by tippy-toe, and no vision outside the car, as the seat mount is inclined, and when you go back, you go DOWN as well… All this at 100mph. Fortunately, this also loosened all the harness belts (YIKES!!) so I was able to KIND OF stretch way up and could sort of see over the dash and cowl hood. HOPING there were no cars in the way, I slid over to the edge of the track, and got the hell off. We tore the seat out, and inspected the sliders, and found the culprit; the side brackets were a new design from Sparco, and overhung the actuator lever on the sliders, preventing them from completely seating. Marked up the brackets, pulled them off, then found a shop at the track with a bandsaw. 5 minutes later, we were re-assembling. Joe missed a TT session doing all this, but finally, we were all set!
I took the car out for the race group Qualifying session, and on lap ONE after the out-lap, still trying to get heat in the tires, I went into T8 at Autobahn South nice and hot, hit the hooks, and…. Instant rear lockup, piles of smoke pouring out of the rear of the car, etc. Trying to wrestle the thing back into shape, I found that not only had I apparently lost ABS, but I also lost power steering as well!! Pulled offlline, and headed back to the paddock, AGAIN, to diagnose and repair.
The mount on the power steering cooler had failed (crash damage), allowing the cooler to drop down and rub on the track until holed, which pissed all the fluid onto my rear tires… Oh, remember the radiator that I replaced? Yeah, that took a beating as well… Brand new Mishimoto radiator, beat to hell, but at least not leaking. We cut a 3” section of line from the power steering cooler and just jumped the two hoses, and called it good.
Finally, Joe got a chance to run the car in Time Trials, and reported that all was good, but he didn’t really like the tires, saying that they just kind of felt numb. His times were good, but… Neither of us had any real practical experience in a high-horse car with slicks, so we were both kind of in the dark scratching our heads on what they would do. Whatever, the car has three pedals and a wheel, we’ll just get in it and drive.
Now, it was my time to hit the grid for the first race of the weekend. Woohooo!! The “Thunder” grid for this weekend was massive, with 50 cars crowding the 2.0 mile track, and with a LOT of heavy metal represented. We were one of SEVEN running in AIX, and since grid is by class, not by time, I found myself in grid spot 13 (with 37 behind me) for the race start. Remember, it’s a 310HP car, so I knew I was going to get murdered out there, but hell, that’s racing! Wasn’t in it for the competition, I was out there to knock off the rust and have some fun. We rolled off grid behind the pace car, did our swerve/brake warmup nonsense, then formed up side-by-side for the last four corners and took the green flag!! I was in the first of four waves to take the green, which put nice separation between various classes. I pulled a move on a rookie AIX driver and pulled ahead of him through T1/T2, nice and clean, got passed by two AI cars, then looked for a gap to set up in to start letting the heavy-metal field by without screwing anybody’s race while I tried to get some heat in the Pirellis which are fairly treacherous when cold. By the time we got to T5, we found ourselves in a double-yellow condition: full-course caution. Practically, that translates to no passing anywhere, the race leader drops to 35-45mph, and the field bunches up behind him single-file. Yikes. I WAS tail-end of my wave, which was perfect for me, with at least a solid lap or two before the next wave back would have caught me. NOW, though, I had about a dozen hungry BMWs piled up in my rear-view as the race leader came around the final corner, and the whole track went green. I got mugged. As soon as we went green, I shot over to the outside edge of the track and just hung on for dear life as the train of BMWs went by, and at one point, we were three-wide going through one of the trickiest corners on the track. Slow doesn’t even begin to describe the pace for me. I was sitting WAY offline, with a constant stream of cars zipping by (including the AIX rookie that I passed earlier), and I was at the tail end of the whole shooting match before I could get back on line and start trying to get heat into the damn tires again. I could have been more aggressive, and forced my way into one of the packs, but I was serious about NOT screwing anybody’s race. Eventually, I did get some heat in the tires, but with all the battling, the race leaders had caught us, and I again had a lot of heavy metal coming by. I was polite, I did point them by, but by then my race was shot, my brain was rattled (remember: 2 years off!), and I just wanted to get through the race without incident. Honestly, it was a blast. Yes, I got passed by everything out there, but who cares?! I was racing again! Eventually, I got collected, and got SOME pace going, and started trying to figure out the tires (which I had hoped to do in Practice and Quals), then started to click off the laps, getting passed here and there, and making a couple of passes of my own. I started 6th and finished 5th in AIX, which is just silly considering how little HP I have, but had a blast doing it. Along the way, I got to see some seriously cool battles, and from the best seat in the house. NO TV coverage is like sitting in a car 6’ behind a pair of drivers going at it hammer-and-tong. Awesome! I did note to Joe, that to me it felt like the tires kind of went “off” towards the end of the race, and I was starting to have issues keeping the back end under me, so I pulled pace a bit to see if they would come back, and they did.
I was done for the day, but Joe still had a couple of TT sessions to go. Embarrassingly enough, Joe wound up turning laps around 2 seconds faster than me, in MY car!!! Granted, he had no race traffic to deal with, but still… Bragging rights to Joe, who proceeded to comment that the faster he went, the more he liked the tires!
Finally done with the day, it was time to finish the wing project, which went flawlessly, if slowly. Then the social stuff, and we wound up leaving the track at 10:15 to head to the hotel. Between the U-Haul fiasco, getting the tires mounted, the seat-mount issue, the power-steering cooler, then finally getting the wing on AFTER the racing was done, we were knackered and frustrated. And hungry. The only think I had to eat all day was one hot dog at lunch, and I was starving. Given the hour, it would be fast food, and we found an Arby’s, so I ordered a “mid sized” sandwich… To which the girl behind the counter said “I’m sorry, we’re out of roast beef…” You have GOT to be kidding. Well, it was a perfect capstone to a frustrating day.
Sunday dawned as a beautiful day, and we “slept in” not having to be to the track until 8:00 for the Time Trial group meeting. Today was Joe’s turn to race, and mine to run TT. Cool! Fun! All the gremlins are worked out, and we’re set to just put our heads down and turn laps. Right? Wrong.
The first TT session was RIGHT before Qualfying (no practice today), so I went out with a simple mission: run two laps, and get the car warmed up. So, that’s exactly what I did, I ran two laps, drove it like a jackass, and when the tires came in, so did I. I pulled straight to grid, where Joe was waiting, but since quals were gridded by (pathetic) time from yesterday’s race, he was in position 38, which is on an incline. I couldn’t sit there with my foot on the brake, or I’d cook them, so I shut down, and left the car in gear while we did the driver change and debrief. The track felt great, the tires were gripping like crazy, and Joe should have some fun out there. For whatever reason, there was a bit of a delay, like another couple of minutes longer than we expected before the field was released. We needed a push-start to get the car re-fired (2-year old peanut battery in a HOT car), and off he went. The did the warmup swerve/brake thing, and took the green flag in single-file, and Joe attacked T1/T2 like a maniac, and thanks to the pre-warmed slicks, he stuck it, and was through T3 in the blink of an eye. I stood at grid with a stopwatch, watching down the track waiting for him to come around. Come around he did, straight onto pit lane, and right into the paddock. I ran down to meet him in our paddock spot, and he reported severe overheating, with 240* water temps, and 280* oil temps. WTF??? My car NEVER does that kind of thing! Wondering if the radiator let go, we let the car idle to try to bring the temps down while we started diagnostics, and all we could figure was that me bringing the car in without cooldown, followed by the extended sitting on grid had just heat-soaked the motor. Oh, well.
I took it out for the next TT session an hour later, ran it hard, with no temp issues at all. Heat soak indeed… While I was out beating on it, I started to notice a LOT of little mistakes I was making; over-braking, too slow on entry, not looking down the track far enough, etc. Yup, I’m rusty, all right! Right then, I decided that if Joe wanted it, he could do the third race, because I needed to learn to walk again before I could run. I just needed more seat time to get my chops back, and trying not to get run over in the race group is NOT the way to do it. Cool, got a plan.
I skipped the following TT session, since it led back-to-back into Joe’s race (race #2 of the weekend), so we fueled the car, ran it to grid, and got him set for the race. Grid spot 13 again! This time HE would learn what it was like to get mugged! Unfortunately (for my ego) there was no double-yellow to bunch the field up, and he got clean track to get the tires up to temp, and he started setting a nice blistering pace out there. I have to say, he was killing it. He still got run over by the heavy-metal, but he held his own with the other stuff. Yes, it helped that the cars were fed to him one by one, and not in packs of ten or twelve, but he still handled it well, and all was good. Fun race for him, until near the end, when they had to roll the pace car, and the field did bunch up again. They released on a green/white-checker format, going green with one lap to go. Joe, however, had temps in the tires, and proceeded to pounce on a sports racer that was snoozing, forcing the issue through T1 and T2, then made the Mustang REALLY wide and hung on to the spot all the way to the checker. He started 6th in AIX, and finished 4th, and it was a job well done.
Half an hour later, with a fresh load of fuel, I went out for the 4th TT session, where I hooked up on track with a good friend Terry in his 2013 Mustang. Stock powertrain, no aero, good dampers and Hoosier R7, up against our barely-aero’d (0* AOA on the wing) 310HP Hooptie. We had a BLAST. He wasn’t in it for times, and we just played tag. He lifted a bit on the straights so I could stay tucked up, then we went at it in the twisties. He would pull a bit here and there, I would return the favor, and once I got the slicks, hot, I really started pushing him in the corners, and we swapped places a couple of times for giggles. We had an M3 behind us, who was reeling us in bit by bit, and I immediately planned on giving him the line and a point as soon as he caught us. Neither Terry nor I were worried about lap times, but this guy might have been, so politeness counts. It took three laps for him to make up the 8-10 carlengths, and I threw the point at exactly the same time Terry dropped two wheels trying to keep away from me, and threw ME the point-by. Well, I certainly wasn’t going to point the BMW by, then pop out in front of him a half-second later, so I just got out of the gas. Terry got out of the gas too, waiting for me to pull out. The BMW popped out, went past me, then slammed on the hooks to keep from over-running Terry, and from there it was three-way tag. Great fun, and I really started to get used to the way the tires acted, even though I could tell the best laps were already gone from the rubber.
Finally, it was time for the third and final race, and Joe went out in a VERY reduced field of maybe 30 cars. From grid, where I was watching the race, I could see my car from the mirror up, and Joe was looking good, maintaining a blistering pace, and “playing” with some cars we had no business being anywhere near. He took the checkered flag, and I wandered to our paddock spot to grab him some water and Gatorade, and waited for him to pull up. And waited. And waited. WTF?? Where’d he go?? I doubt they would have pulled him for impound, since AIX has almost nothing to inspect post-race. I wandered back towards tech, anyway, just in case, and I found him. Sitting in the “Sin Bin.” Formally, this is known as “Body Contact Impound.” If you do something dumb, like hit somebody, you have to report and fill out paperwork. If you do everything right, and somebody hits you, you STILL have to report and fill out paperwork. Well, Joe was doing paperwork. He was fine (big relief!), and the car was MOSTLY okay, aside from a bashed in driver’s door with a giant donut on it. Of course, this was the LAST undamaged panel as supplied with the car from the factory. Not anymore!! Fortunately, John has the “Official American Iron Bodywork Kit” also known as a 2x4 and a 5lb sledgehammer. A couple minutes spent with the hammer, and the door was straight enough for me. Adds character, I think! As he entered the braking zone for T5, he glanced up and saw the GTS2 BMW right behind him, he hit the brakes, turned in, and the BMW was RIGHT there. This was a low-percentage move called a “dive bomb,” initiated with no warning, from a car running solo, trying to get around a car running nose-to-tail with in-class competition. Unfortunately, since at the point of contact, the BMW’s front wheel was even with our driver’s seat, the BMW technically had the right to be there, and it was Joe’s “fault” for turning in on him. The race director issued a single-point penalty on both licenses and left it at that; it was just a “racing incident.” Joe got the point for turning in, the BMW driver got the point for being a knucklehead and trying the pass in the first place.
For nearly 10 years, the car has been flawless. Not a single mechanical DNF, never failed to take the green, never broke down on track, never had chronic issues of any sort; you just put gas in it and drove it. Then, in one weekend, we got screwed by U-Haul, had a seat-mount failure, destroyed power steering cooler, damaged radiator, massive overheat, failing battery, and got hit on track. Oh, and Arby’s was “out of roast beef”
But damn, was that a lot of fun!!
dark steed
Resident noob
Winder, GA
Good times! And bad! Good read, sounds like y'all had fun in spite of all the mishaps
kerrynzl
Tauranga, New Zealand
Is that "sin bin" for real?
Here, If you're doing a late braking manoeuvre and give the car in front a "Liberace" it is chalked up as a racing incident.
SoundGuyDave
This Space For Rent
Yes, it's absolutely for real. If you have ANY car-to-car contact, you get to do paperwork, and the "incident" gets reviewed and a judgement rendered. This particular incident really WAS a "racing incident," and a 1-point hit on the license is as small a penalty as can be handed down. Our rule set for passing is fairly simple (abridged version):
1) The overtaking car has the responsibility for making the pass cleanly.
2) Each car MUST allow at least 3/4 car-width of racing room at all times.
3) The overtaking car gains the "right to be there" once the front tire is even with the other driver's seat.
Dive-bombs are late-braking maneuvers that have a low-percentage chance of success because the overtake actually happens AFTER the other driver has started the turn-in, and in severe cases REQUIRE the other driver to take evasive action to avoid contact, not just run wide of apex to leave room. In our case, the contact evidence is clear that the BMW had his tire next to our seat, so we had SOME culpability in the incident. The BMW, however, never showed Joe a nose (demonstrating intent to overtake) and was in direct trail when Joe entered the braking zone, which on this corner is a whopping 100' long, on the brakes at the "2" marker, and turning in at the "1." At 95mph, that hundred feet disappears in an eyeblink. The BMW driver should have known that there was NO way he could make it through without contact unless Joe was staring at him in the mirrors the entire way through braking and turn-in, thus it was indeed a dive-bomb, and he caught one point on his license for his pains. Very minor damage on both cars, neither car lost control, and there was no change of position as a result of the contact, so really no big deal. If we really wanted to press the issue, we could have gone to video to see if the other driver had two wheels on the VERY tall berm or not. If he didn't, then he didn't leave sufficient racing room, and the fault would have swung squarely on his shoulders. Not worth the time and effort in this case, as both Joe and the BMW driver agreed that it was "just a racing deal," and there was no significant damage. For our part, the dents pounded out in about five minutes, and the door is straight enough, if no longer pristine and pretty.
The reason we do the Body Contact Impound is to reduce car-to-car contact overall. It enforces the rules, reminds drivers that there is a penalty, and tends to help identify possible "problem children" out there. Think of it this way... If you get punted (on the brakes, and the car behind runs into your rear end sending you off the track or out of control), there's no way it's your fault, right? You can't control the other driver. However, if this is the eighth time you've been punted in five races, there may be something else going on here. Once your license accumulates 10 points in a season, you go before a review board, and may have your license suspended, be put on provisional (rookie) status, or a wide variety of larger penalties than are handed out for minor matters. This is VERY rare.
In the end, this is CLUB racing, with nothing at stake other than a plastic trophy and maybe some contingency tires. There's no reason for us to be running into each other out there, and the "Sin Bin" is the simplest way of reinforcing that concept.
SoundGuyDave
This Space For Rent
Good read! Do you have a build thread for your car?
Thanks, and no, no build thread, but here are the gory and boring details...
Safety/interior:
Sparco ProADV containment seat, Schroth "Enduro" 6-point belts, QuickCar mesh window net, on Joe's Racing window net frame, Sparco steering wheel, Woodward quick release, Sampson Communications radio system, Longacre drink bottle, CoolSuit system, custom switch panel, Traqmate "classic" DAQ, 5lb ABC extinguisher (fire bottle on the shelf).
Brakes:
GT500 4-pot Brembo calipers, Girodisc 2-piece rotors, Hawk DTC-60 pads, 3" brake ducts with FTBR backing plates up front, bone stock rears with DTC-60 pads.
Suspension:
AST 4100 dampers, 750/300 springs, Strano's bars (full hard front, full soft rear), GT500 front control arms with Steeda hard bushing inserts (FR500C bushings on the shelf!), X5 ball joints and bump-steer tie rod ends, MM rod-rod rear LCA's, Steeda competition UCA, MM rod-end PHB.
Chassis:
Custom cage (10 points, A- and B-pillars are plated in), Steeda radiator support crossmember, Boss 302S front bumper beam with tow loop, MM K-member, stock rear bumper beam with tow loop.
Powertrain:
Bolt-on 4.6L-3V, internally stock, dyno-tuned. C&L racer CAI, Roush underdrive crank pulley, Mezeire electric water pump, ARH long tubes, X-pipe, SLP 18" resonators, FR500S mufflers; Fidanza billet aluminum flywheel, SPEC 2+ clutch, stock 3650 trans, Spydershaft 1-piece aluminum driveshaft, 3.73 gears on a stock LSD.
Aero:
G-Stream C800 wing, Steeda Competition fascia with integrated splitter; custom splitter and fascia is in the works.
Rolling Stock:
5Zigen FN01R-C 18x9.5 wheels, +36mm offset shod with whatever I can get my hands on, currently Pirelli P-Zero "DH" slicks.
tjm73
of Omicron Persei 8
Rush, NY
How does Arby's run out of roast beef?!?!? IT'S WHAT THEY DO!!!!
46addict
13726548
Lawrenceville, GA
Good to see that the stock trans and LSD have stood up to the abuse.
And kudos for the well written post. Track addictions make drug addictions look cheap and boring. I need to find some time to get my car and funds sorted out so I can get my track fix. Just going 50-70% on a HPDE 0/1 level turns into ear to ear grins.
SoundGuyDave
This Space For Rent
Well, sorta... The diff is on it's fourth set of carbon clutches, and will turn into a T2R in the next big "upgrade phase." The 3650 is a solid trans behind a 4.6, but with 32,000 miles on it (50% track), the 1/2 synchros are completely shot, and 5th gear is utterly worthless. Do you NEED to upgrade the trans? No. Can you BENEFIT from an upgrade? Yes.
For an HPDE-0/1 type of run, just flush the fluid, throw on decent pads, and go have fun. Doesn't have to be expensive at all at that level. The money starts to add up once you get off street tires and onto a race tire of some sort, with all the supporting mods needed (more camber, higher wheel rates, extra wheels, better brakes, tire cost increases, etc.).
If you can focus on NOT competing with anybody in your run group, and just working on mastering the track, you'll wind up finding somebody in your group that runs a similar pace, and you can use them as a "rabbit," which usually ups the game for both of you. Study where/how he pulls on you, and study where/how you catch him, then compare notes with him. You might just make a lifetime friend!
46addict
13726548
Lawrenceville, GA
Once again, very well said.
My first track outing was at Road Atlanta in 2011. My car had nothing done to it minus FRPP K springs on stock shocks, Hawk HP+ pads, and new OEM fluid. I probably should have left the stock springs on but I was even more impatient than I am now and didn't know better. And with me being a novice, pad material didn't matter as much as long as they had good cold bite. Also, the event I was in required new drivers to be put in the kiddie pool group with a 100mph speed limit and an instructor on board. This was very welcoming to someone like me with no track experience. I was instantly hooked and went back two more times on the same setup. Going out only once or twice a year, I haven't "graduated" from the HP+ and street tire level yet, but I'm not worried about winning anything or speeding up my learning curve. What I meant in my post is it's a thrilling experience just cruising around at 70-80% and trying to keep inputs consistent, holding your line, etc. My last event was at Roebling Road two years ago and I need to go back out soon for another fix.
:Caffeine::driver::party52:
SoundGuyDave
This Space For Rent
"Cruising around at 70-80%" is absolutely not a bad thing to do, and I offer kudos for your focus on consistency. That will give you a solid foundation to build on as you develop as a driver. Biggest thing is to have fun; otherwise, what's the point?
kerrynzl
In NZ the passing manoeuvre is the responsibility of the person doing the passing.
If you come unstuck, you just claim the front car "just shut the door on you" [I've heard this many times]
All the officials care about is if everybody is OK afterwards.[no fights erupting etc]
Seriously, We NEED your sort of ruling in New Zealand.
Especially for the guys that are into valuable historic and classic racers.
By the way , I loved the story.
It brings back a lot of memories of some of my tribulations
[The only thing missing is the wife that is not amused]
SoundGuyDave
This Space For Rent
In the club-level stuff, the NASA passing rules are actually considered fairly liberal. A lot of other groups require a full car-width plus 6" racing room at all times, but yes, I agree with you, there NEEDS to be solid, consistent oversight, or it becomes a checkbook thing, where the guy that can afford the repair can just intimidate the guy that can't out of a position.
One endurance series I run in has an automatic at-fault for BOTH drivers, and you have to do a LOT of arguing to be held blameless. Honestly, I like that. It's club-level, not pro, and over a 12 hour race, there's really no NEED to force a pass until the white flag is out.
In practice, our system seems to work really quite well. If you touch, you go to the Sin Bin and fill out the paperwork, which includes your version of what happened, who YOU would assess has the blame, and they take a video walk-around of the car to document any damage. The Race Director may do a quick interview/discussion with one or both drivers. At that point, you're released to go find a hammer. It's relatively quick, relatively painless, and it really does work to cut down on the nonsense. Unless the contact caused a change of position or a loss of control (even a minor loss) it's usually considered "just a racing thing," absent other circumstances, like repeated encounters between the two drivers, or something like that. Normally, if you pull into the Sin Bin, you get AT LEAST one point on the license, and let's face it, if you get hit 10 times in one season, you're probably doing something wrong... Bigger contact, or mitigating circumstances can/will result in harsher penalties. That can include a cash fine (charity donation), having to pay for the OTHER guy's repairs, being put on provisional status (rookie status), suspension, or flat-out ejection. We also do safety-gear spot checks in impound, with a $50 "fine" for each missing/expired piece... You can find the NASA CCR online (nasaproracing.com) which has the full set of competition rules in it. Perhaps you could propose a review of that by your sanctioning body? From what I can see, it won't "cost" the club any new positions to implement; you already have a Race Director, I'm sure, and the tech folks are the ones that do the video and paperwork. Just a tiny amount of administrative load, and it's up and running.
LOL!! I used to have one of those myself... And yes, it was a fun/frustrating/fun/expensive/fun weekend.
ddd4114
Columbus, OH
Dave, I think your bad luck is contagious...
I had no issues the whole weekend, and on the way home today, almost all of the ratchet straps on my little utility trailer loosened up from driving over shitty I-65 potholes for almost 2 hours. Once I got into Indianapolis, I noticed that my EZ-up (thanks again for helping me pack it up, by the way) was sitting pretty far outside of the trailer, but I have a long steel cable to keep everything attached, so I decided it would be ok to fix it at the next available rest stop. However, I wouldn't get to one for dozens of miles. Well, as soon as I pulled onto I-70, about 4 miles from the next gas station, the EZ-up falls off the side of the trailer and starts dragging on the ground, but fortunately the cable keeps it from flying off behind me. I was able to quickly find a spot to pull over and spend 10 min redoing all of the loose ratchet straps. At least the race wheels didn't fall off! One of the legs on the EZ-up has a nice battle scar, but otherwise, it seems to be salvageable.
If that was the only issue, I'd only have myself to blame, but about 20 min ago, I got a call from my bank saying that my debit card number was stolen. Apparently somebody just charged $140 to Popeyes and $600 to the Apple store. I've only used my card five times since Friday morning, and all were at seemingly legitimate establishments in Joliet. This is certainly more of an inconvenience than losing 10 min on the side of the highway. However, it's still not as bad as going to Arby's and being denied roast beef.
Hopefully this fulfills my quota of bad luck...
Also, as a small detail to add to your story, you forgot to mention how you guys spent 10+ min organizing your tools while packing up on Sunday only to have Joe drop the toolbox off the tailgate and undo all of your work.
Great seeing you again at the track this weekend.
Dan
ddd4114
Columbus, OH
I don't know how you can do that, but I'm glad they did, because my bank picked up on it really quickly. There were a couple other smaller transactions that were made, but fortunately only one got through for ~$100 before they denied the other charges. They said it will be reimbursed, so at least the only thing I'm going to lose is time and sanity (from the little I have left of both).
SoundGuyDave
This Space For Rent
Oh, man, that sucks! I'm sorry to hear about that. "Life hack" tip: get a second card (with a different number) assigned to your account. Use one for purchases/ATM stuff, and the second for online recurring bill payments. That way, if you have to cancel your card, you don't have to re-input your data into everybody you pay bills to...
Dan
LOL!!! I completely forgot about that! Yeah, just add it to the pile!
It was great paddocking next to you, and thanks for the use of the jumper cables!
TLeroux
You're looking at this all wrong. The truth is that Saturday I was faster than Joe and on Sunday you were faster than I was, so bragging rights are all yours.
Now this sadly is nothing but flat out lies. I was not lifting to let you keep up, I was lifting to keep from pushing all four tires off and to keep the back wheels behind the fronts in the fast sweepers. If I kept it neat, I couldn't use the power to pull away, and if I used the power, I had my hands full trying to keep it going in the right direction. You also skipped over the helpful corner workers who were putting up blue flags at nearly every corner most laps even after we had changed the running order.
I told you after Arby's was out of roast beef, you shouldn't have put all that order at Popey's on one card, it would get noticed.
