I have noticed everything from 160 F to 190 F T-stats being used. How low is too low ? Has anybody correlated various T stat ratings with stuff like IAT's.... and /or eng oil temps, eng coolant temps, cyl head temps, etc ? On my SCT-X3, I can adjust the low speed eng fan turn on threshold over a wide range..and ditto with the high speed eng fan turn on threshold. In fact, they overlap by quite a bit in the middle. On paper, it even appears that the high speed threshold can be set to a lower turn on temp, vs the low speed turn on temp. (I have not tested that..yet)
Right now I'm using a 190 F T stat. Low speed fan set to kick in at aprx 204 F.... and I think the high speed fan is set to kick in at aprx 214 F.
Idling in the driveway, (summer time, 73 F day)... the coolant temps creep up to 204F, then low speed fan kicks in.... and temps drop to 194 F....( 2-4 mins)...then low speed fan shuts off. Temps start to rise back up to 204 F, low speed fan kicks in, and the cycle just repeats itself over + over.
I'm assuming IF a lower rated T stat is used, that both the low + high speed turn on thresholds also have to be reduced accordingly ? (I forget exactly how low the SCT-X3 will allow me to reduce the thresholds, but it was quite a bit)
Way back when, (since lost the url), I saw a graph of eng coolant temps vs cyl wear. As temps came down, cyl wear increased by a bunch. The graph, if I remember correctly went from 140- 210 F.
Will the lower T stat rating + lower fan speed thresholds even work.... or will the temps rise anyway, if stuff like sustained and high rpm used ?
