Window'ed
Heaten m90
Yesterday, me and my buddy went to tune his 14:1 460CI motor and it had a catastrophic rod failure. We had a spark issue at first due to a low voltage condition, with that corrected we began making pulls. Starting at 32° of timing with c16 fuel the motor sounded healthy. After the first 2 runs the engine had ran through the 5 gallons c16 i brought. So we switched to VP110 and bumped the timing up to 35°, at only 6k RPM with 12.1AFR it chucked a rod out of the side of the block. The Aluminum rods were not replaced during the rebuild as they only had 60 runs on them(one did have a small nick in it but it was releived) The rod broke at the thickest part. I posted a few videos on youtube..... looks to be an isolated rod failure?
https://youtu.be/pXxlzKZA1Xs
https://youtu.be/3Qeg_lv-Cfc
https://youtu.be/AOqhUFIHTt4
Wes06
Oww
Also, vertical recorded video....do you want to give people cancer? Because that's how we get cancer
drive_55_not
Hummm, Seems to me failure was imminent on a 14:1 c/r motor when you went from 116 motor octane to 107 and added timing ??
Wes06
well if the 116 octane was near its spark limit, and you reduced octane followed by adding timing. then........yes..............huge mistake
Heaten m90
Generally you keep adding timing untill it stops making power and it was 110 not 107
Wes06
welcome to reading the fine print on shit
sounds like you need some nitro
Heaten m90
You're making shit up
VP-110 RACING FUEL - Not your “standard” 110! Highest rated MON of any 110 fuel on the market. ... In fact, it's higher than any other 110 octane racing fuel on the market.
Wes06
lol heaton, your retarded, read the fine print
Heaten m90
Clearly, we were only at 35° of timing though. The motors had way more timing in the past. 110 is 110
tjm73
of Omicron Persei 8
Rush, NY
RON, MON or R=M/2 (Octane)?
"Formulated for use in naturally aspirated engines with CRs up to approximately 12:1-13:1." Your buddy is at 14:1 you said. So....
