Wire Tuck Thread
one eyed willy
Pizzle fo shizzle
Lakeland FL
Crank sensor wire, I didn't cut mine, I routed it with the headlight harness on the outside of the frame, then came under the A/C compressor back to the sensor. Coiled up the slack. With all the shielding and drain wire I didn't want to risk messing up the resistance of that wire.
Jason
Fort Riley, KS
Thanks for all the constant help. It really is appreciated. I'll take a look at it tomorrow. I wasn't sure if it would reach all the way to the fender.
Jkoogler
I ran mine like he said along the outer frame rail you will have plenty of slack. Looking good I take it you took your heater box out?
Jason
Fort Riley, KS
Nope. I did cut the back of the glove box a little. I've had the car for 9 years and only used it to keep my insurance in there.
richman
WTF!!! AGAIN AMERICA?
Michigan
Do you ever feel like just dropping your car off at a dealer and say," whatever you will give me for it! I just don't want to look at it anymore!"? Need to work on something else for a bit.
Jkoogler
I'm rewiring my car and just finished the wire tuck would anyone be interested in my engine wiring that I redid for the tuck.
wildbillcody
tennessee
Thanks guys the computer went to the fender the fuse box went under the dash and the battery went to the trunk we also shaved quite a bit on the engine bay
richman
Michigan
World's longest wire tuck..getting close!!! Well closer anyways..just looking up these connectors now because my labels fell off and I forget what they go to since I took them off like 4 months ago!! Getting excited to hear it run for first time this year!
richman
Michigan
Bump!! Ok..waiting on an 07 coolant conversion but I have everything wired( as far as I know) and was just going to crank the engine over to hear it crank..there isn't any coolant in the engine so I didn't want to start it..but. no crank!!!..soo..all gauges light up and work..odometer is reading miles all lights work..I can hear the fuel pump..I hear clicking with the relays..I checked battery it's at 12.49 volts..power to the starter.. (no ground line front starter but I read somewhere that it's grounded just being attached to flywheel/ mount?) I replaced starter relay just to be carefull..I took starter off and had it tested..they said it passed...been reading up on some no start threads..one thread said to check grey wire next to coil pack? I didn't see a single grey wire sticking out to me....and yes. I have a clutch and yes I was pressing it in wile trying to turn engine over..
Any other pointers would be helpful...thanks
onehotpny
Aragon,Ga
I would think even though starter is grounded to block , it would still need a ground wire/ strap on it. Does engine turn over at all when trying to crank it? Also you know that the clutch pedal switch can go bad, you can straight wire the pedal switch if needed till you can replace it. Mine went bad, but i never replaced it, I just make sure that my car is in neutral before I start my car have been this way for years now.
onehotpny
Aragon,Ga
I lurk on this thread all the time but im terrified to try this!
It's not hard to do the wire tuck , you just have to make sure to label all the wires and it's also a good idea to take pictures of before starting the wire tuck and also during it for references.. It takes time to do the wire tuck, not a fast project in any way.. You only have problems when you get in a hurry or don't take plenty of pictures to help with remembering where things go.
Roush fun
South Bend Indiana
It's just the one wire I would miss that would fuck shit up!
onehotpny
Aragon,Ga
Hahahaha!!!! good one.. the wire are color coded, so not that hard to identify . I learned that while doing my wire tuck. after taking all the time to label everything, i then noticed all the different color wires. It's more of just not getting in a hurry when doing it..
Roush fun
South Bend Indiana
I hear ya, once i get my shit road worthy again i may give it a shot!
