I am replacing the leaking turd in my 2011 GT and heard these work much better. Can anyone assist me on where I can buy one or if anyone has one laying around? After a new clutch, flywheel and shifter this will be the final end getting this car to shift much better I hope.
I bought mine from Tascas ebay store. It definitely helped me, the engagement point is higher up as it moves more fluid. Plus it looks much more beefy than the stocker.
I like the old mechanical lever arm ones with the z bar. You could adjust it exactly like you wanted it. But it made headers damn near impossible.
I ordered a gt500 clutch master cyl not that long ago from Tasca. Heres the info
DR3Z-7A543-A Master Cylinder $82.74
Be careful with the install. My pedal would bottom out the clutch master cylinder just before the pedal hit the stop. So I put a thick fender washer under the stop to take the stress off the master cylinder.
I never heard anyone else with this issue. Maybe no one ever checked it? Maybe there is some variation in the parts?
