Question About tunning???
BlackMustang690
BlackMustang690
Houston, TX
Need to return my car back to stock tune its a 2007mustang gt, im either selling it or trading it in. im probably going thru a local dealer to tune since its going back to stock. Could it be tuned back to stock with larger injector 39lbs and piggy back fuel pump or do I need to get stock ones?
Do you have a hand held tuner at present?
I think you'll need to change to injectors
curious how was the car tuned previously?
ok, so how did the car get the tune to accommodate those mods?
BlackMustang690
BlackMustang690
Houston, TX
thru a handheld which he didn't not have when I purchased the car. I don't want to spend the extra money to buy a handheld to tune it back to stock. so I was just going to go thru the dealer since they just charge the 1 hour of labor $70. but I wanted to know if I really need to switch out injectors or if it would be fine to keep the current ones.
I see.
I'm sure you could find a set of stock injectors cheap and sell the 39#s for more then the stocks cost.
Exley
Southeastern PA
Wouldn't he need to put the stock pump back in too? I would think the aftermarket pump might do strange things if it has the stock fuel pump voltage table to go from.
07graygt
I should have a set of stock injectors here in a few weeks if you can wait that long. Will also have the stock fuel pump.
BlackMustang690
BlackMustang690
Houston, TX
yeah but i just have a piggy back fuel pump i just need to remove that.
