Well we hit a little bump in the road. We don't like what the oil pressure was doing in the higher rpm ranges, so they are going to put .018 restrictors in -- plus send the brand new moroso oil pump back to get looked at. This motor has the Jesel keyway lifters in it, and there was another thread on here discussing if people were running those wide open or with restrictors. Well we are going to run restrictors.
Because of that we still have not made an 8000 rpm pull (why would we if we didn't like the oil pressure). So it looks like by the time the restrictors are put in and the pump comes back from Moroso it will be a week or two.
So far we are at 1144 @ 7500 rpm and we have 500 more rpm to go as well as adding the plenum spacer. I think it will be 2.0 hp / cubic inch when its done.
Honestly, based on what I have read, I am not seeing much of a difference between this head and the C460 head. However, to be fair, I got these heads from a guy where the exhaust ports were done with nitrous in mind, and this of course is an N/A application, so maybe it would have been different with a brand new set of heads. We are still not done yet so we will see. I will post the dyno sheet and video once its done.
On a positive note, this combo is absolutely killing the old combo in power, throughout the entire curve from 5,000 rpm up. At some points its 250+ hp above the old combo--and we are not done yet.
