So i picked this thing up thursday night and it ran okay, not great. It has had a lot of work done under the hood, built motor, AFR 185 heads, E303 cam, 1.72 Scorpion Rockers, all of the egr and emissions crap unhooked, Bassani equal length headers, orx, and side exit catback. Today i spent a few hours cleaning things up under the hood, checked for codes, adjusted the tps, set the timing at 16 degrees(they had it at 20 degrees and the truck didnt like it). Here is a walk around after getting everything done. Next will be a complete tune up, fuel filter, transmission neutral safety switch and remove all of the egr and emission crap under the hood. The smog pump is hooked up but the air lines are disconnected so you can hear the pump working and its annoying. Going to swap in an aluminum radiator with slimline fans and shroud.
https://www.youtube.com/watch?v=xiQj3V-k70M
