Nah, regular bulbs and swapped out for brand new ones.Where the bulbs leds? I tried using leds for the license plate lights, and the circuit decided it didn't like them (would blink twice when arming alarm just like the normal bulbs, but would not illuminate when running lights were on). I put standard bulbs back in and they work fine now.
I know, that's my point, short of pulling the wires apart, I don't know how to determine where they start and from which plug. Forscan tool comes in tomorrow so we'll see what that says.You dont have to pull wires apart. Just need to figure out which wires in what SJB connector go to the bulbs that do not work. Than with the sjb removed, continuity test the two wires going to the non-working bulbs. The hard part is figuring out which SJB connector!
The keys are not linked to the SJB... i have swapped several in my garage and never had to had to have 2 keys. Key data is not maintained within the SJB. Yes it needs to be configured for the car, but the keys have nothing to do with the SJB configuration.Actually you do. It is a module and the vehicle needs to be trained that there is a new module in the car or all features will not work. Most times you need 2 keys also.
Why does water / moisture even getting into the SJB ?? Is there provisions for a drain ?
Some silica gel / desiccant would / should solve solve moisture ingress problems.
OK. I guess the Work Shop Manual is wrong then?The keys are not linked to the SJB... i have swapped several in my garage and never had to had to have 2 keys. Key data is not maintained within the SJB. Yes it needs to be configured for the car, but the keys have nothing to do with the SJB configuration.
I get that. However basics like programming are not something they would be wrong about.Wouldnt be the first time! I worked as a dealer tech for 15 years.
I have become quite familiar with the SJB with this swap and wanting to add features I did not have (rolling door locks and oem fog lamps)
1 Ford told me rolling door locks will not work on mine, they do.
2 Ford told me they can enable fog lights, this was not correct. Even enabled, they still didnt work. I had to add jumper to bypass the SJB.
So yea, I take info in shop manuals with a grain of salt. I lost track of how many times the diagnostic steps did not help me find an electrical issue.
My SJB was in "factory mode, configuration incomplete" when I first connected to mine. All factory options were working. To me that means at some point, something was done to mine and the programmimg was incomplete. Yet everything worked.I get that. However basics like programming are not something they would be wrong about.
It is with the 10-14 cars. 05-09 is in the PCM.I was always under the impression the key data was stored in the gauge cluster.
