Given the space constraints for the fitment of headers, it's almost impossible to make the primaries of equal length. Just about all headers on the market whether they're true shorty, mid length shorty, 3/4 length, or full length will have unequal length primary tubes.Wow I'm confused as to how that would flow. All the tubes are different lengths too. Not alot of engineering in design.
In my experience, LTs only make 3vs sound better, though with ATAKs and catless it will be wake the dead loud.Thanks guys! I've had these for awhile and finally decided to get em on. I'm so old school, I'm scared of all the computer stuff in cars. I'm hoping sound doesn't change alot as I always get compliments on it. Catless straits to borla ataks.
Do yourself a favor and use ONLY Motorcraft MLS gaskets. Don’t use any aftermarket paper gaskets as they will leak and you don’t want to do the job again.OK. I finally got started and it appears I'm going to see a big improvement with headers as the pipes on it were really rigged up. But I have to say guy did a good job welding lots of little pieces together. I had to get an impact to get it apart. Ran out of light so hopefully get manifolds off tomorrow and start install. I have gaskets but they are D shaped ports. Should I get gaskets for round pipes? 2v style? Thanks
Yes, you can indeed cut the ball off the header flanges and run straight pipe between the headers and the X-pipe. If you use the correct size band clamps on each side of the straight pipe it'll be nice and solid.OK I do have one question. Can I cut the ball off end of header and just run straight pipe to x pipe with the sleeve clamps? JBA headers are made this way. It would save me $$$ and maybe flow better also. Just wonder about movement and vibration. Thanks
