I want one of these, but i have a midmuffler with side exhaust. Anyone have the sts turbo setup with side exhaust?
I wouldn't recommend the STS system it has a bad problem with the oil pump setup and it also will not work with your side exhaust. If you want something underneath the car go with the system SD has, it could be tied into a side exhaust but a side exhaust setup will cost you lots of HP with any turbo setup because of the restriction to flow. I think Cragar is now doing the marketing for SD's system.
Earl
Or here at Exile Turbo Systems.............
http://www.exileturbo.com/products/item_details.asp?idProduct=51
Quick undercar shot so you can get an idea...............
Side exhaust would be a piece of cake.
Surely they have fixed that problem by now.
You'd think so...
A buddy of mine is running the STS kit on his shop's '06. Nothing but problems with the oil pump. He's also torn several silicone couplers going up driveways because the kit hangs so low. Also, the turbos sound like kazoos...not very subtle or turbo-like at all. I'm not impressed.
Surely they have not. Plus, the damn turbos are in the back of the car. Kills the velocity of the exhaust gasses. Also, the distance kills the boost. I've had my car on a dyno with an STS Mustang on the other side of the shop. At 8 psi my car was 45 hp better than the STS.Surely they have fixed that problem by now.
You'd have to call Rick at Exile for an exact price but should be somewhere in the $7500 range.whats the price on one of these kits(tuner)?
Well do you really think they have one on the shelf after 5 YEARS?
Wish i could get my hands on one of the last four on the shelf.
