Engine Code P0745
Lee's05GT
Formally Qksixx
Tacoma,Washington
Well my check engine light came on, I looked the code up and it says its something to do with the Pressure Control Solenoid A, when It came on I had the O/D light flashing as well then it stopped. Im not really sure what all is going to go into fixing the problem. Im going to clear the code and see if it comes back or not. Anybody ever have this code come up? BTW trans is an auto.
Found something here http://www.sctflash.com/PDF/3000-3015 small.pdf page 5 under DTC Says, Pressure control solenoid malfunction.
Doug M
Fast Cars & Freedom
AL. Baby
^^Mine did about the same thing, o.d. light would blink and would not shift into od. and second gear band was broken, $1650.00 was my cost.
Lee's05GT
Formally Qksixx
Tacoma,Washington
holyyyy shit lmao. Id be better off just finding a used tranny, if thats my case. When you drove it could you tell a difference? Because when im driving mine everything feels fine, shifts fine everything.
Doug M
Fast Cars & Freedom
AL. Baby
^^Just started hesitating going into the next gear, so I thought it would not be long before it would stop shifting. when its your daily driver you can't take as many chances as you normally would, oh and I just thought it was the sylenoid, they tore it down and then said it was the bands as well, you never know!!
Lee's05GT
Formally Qksixx
Tacoma,Washington
Yeah that is true, well mine is shifting fine I cleared the code just now so we will see if it comes back, if it does ill just buy a low mileage 5r55 for now until I go fully built
Sent from my ADR6300 using Tapatalk
Doug M
Fast Cars & Freedom
AL. Baby
yea thats a good route to go, I cleared mine as well to start with, but came back on shortly after I read the codes of a bad sylenoid, then I knew it was over. ha ha.Good luck.
tmcolegr
It's All About the Build
Central, FL
The 7G391 solenoid body assemblies were known to have issues on 2002-2005 T-Birds and 2005 Mustangs equipped with 5R55S transmissions. In April 2007 there was even a Customer Satisfaction Program 07N08 for vehicles registered in CA, MA, ME, NY & VT that covered this part under the emission warranty out to 3 months / 50,000 miles.
A revised part# was released several years ago.
Lee's05GT
Formally Qksixx
Tacoma,Washington
Interesting, well I hope it doesn't come back up. If so ill be looking for a new transmission
tmcolegr
Central, FL
Chance are it will. I had to replace the solenoid body assembly in my 05 @ 8,000 miles. Vehicle was over 36 months, so I got the privilege of paying for the part and doing the install myself.
Lee's05GT
Formally Qksixx
Tacoma,Washington
How much would you think something like that would cost to do?
tmcolegr
Central, FL
about a 2 hour job on a lift, plus parts. Probably would be a good time to change the fluid & filter since the majority of the fluid is already drained.
The concern I would have is the solenoid body assembly is a known issue. If/when it fails, if caught in time the transmission may not have suffered internal damage. Continue to drive it and it will lead to a major failure.
Lee's05GT
Formally Qksixx
Tacoma,Washington
Where can I buy the part that I need besides Ford, or is that the only place
tmcolegr
Central, FL
I purchased mine from Ford to make sure I had the latest/greatest part that was available
Lee's05GT
Formally Qksixx
Tacoma,Washington
So what do I need to ask for when I go in? People at Ford here are retarded
tmcolegr
Central, FL
No problem
I hope this cures your problem and your transmission has not already suffered an internal failure. Mine did, but that's another thread
Lee's05GT
Formally Qksixx
Tacoma,Washington
I hope not its been on for a few days, what do I need to look for as far as damage goes anything in particular
tmcolegr
Central, FL
burnt smelling/looking fluid and/or debris in the filter or pan. Even if there is no indication of a failure, that does not mean there hasn't already been damage done to the clutch discs or bands.
Doug M
Fast Cars & Freedom
AL. Baby
^^True, mine hit one day and a couple days later i was getting it fixed, bands were already shot!!^^^Thanks for all your help on the trans problems, I wished i had a stick car for sure..
