§ 13:62-3.6 Helmets and eye protection
(a) All drivers shall wear a properly secured, full face helmet, with face shield, which meets or exceeds Snell Memorial Foundation Testing Standards M or SA, incorporated by reference herein, as may be amended and supplemented, which has not reached the expiration date established by the Snell Memorial Foundation at the time of the event. The standards are available from the Snell Memorial Foundation, 3628 Madison Avenue, Suite 11, North Highlands, CA 95660.
A Nomex, or similar fire-resistant head sock is recommended to be worn in conjunction with the use of the full face helmet with shield. The use of open face helmets and goggles shall be
prohibited.
(b) "M" (Motorcycle) Snell rated helmets may be used in all motorcycle events and automobile events where fire ratings are not required.
(c) "SA" (Auto Special Application) Snell fire-rated helmets shall be used in all other applications.
(d) Helmets shall not be required under certain instructional and guided tour events where the maximum speed on the track shall not exceed 55 miles per hour.
(e) All helmets used by riders on motorcycles and open air race cars shall be full-faced and shall be worn with the visor in the closed position while on the track, the above rating and
standards not withstanding.
(f) (Reserved)
