So why don't 10in wide square setups work?
Jucostud
booooost'd
North of Dallas
I don't know of anyone with any issues with 18x10's. There is even a few cars with 18x11's and 295/35/18 bfg rivals.
oldlugs
los angeles
Liking that polished hood! Wonder why we don't see more of them.
Gleamin05
B.C. Canada
Do the AMR 18X10 +48 offset fit the front with stock struts? I get a lot of mixed answers on the +48 fitting? Would like to hear from someone running them. I am looking at running 285/35 tires as well. Also will they clear big brake kits?
RideThePony14
NJ
Looking to do 18x10.5 +30 squared with 275/40/18. I know theres gonna be poke, but i don't mind a little. Will a 275 tire on a 10.5" rim sit pretty flush or will it be a little stretched?
Sharad
Site Sponsor
Official Vendor
Fort Myers, Florida
20x10 +48 clears. Can't speak for the 18".
John@Trackspec
Official Vendor
The 18x10 APEX EC-7 that we are doing a group buy on right now fit with no issues. Another great option!
18x10s come in ET43 for a perfect fit. Clears most big brake kits too! Installed on STOPTECH 15" BBK with room to spare. Above car is NEEMA's from this forum. Comes in silver, anthracite, and satin black.
More fitment pics here
Trackspec Apex Lightweight EC7 Wheel Group Buy
Gremlin85
MA
Would you think a +45 would work?
I was looking at a square setup of 20X10 with 45MM offset on all corners.
csamsh
OKC
45 and 48 will start to get close to your swaybar endlink stud and strut housing up front
Gremlin85
MA
+40 is perfect, but yes, a +45 is better than a 48... 48 won't always work.
I'm pretty nervous to pull the trigger on the 20X10 with +45 all around. I was hoping to run a 275 wide tire or up to a 295.
I'll have to look into it more.
Thanks for the input!
1hot427
Airdrie, Alberta Canada
I think I'm going to pull the trigger on Trackspec's EC-7 group buy deal, +43 on the 18 x 10's. 275 40's shouldn't be a problem and you get a race certified light weight wheel for under $300.
csamsh
OKC
If you want to be safe...just do the ARP hub/stud kit and run a tiny spacer if you need it.
AlbertD
Tucson, AZ
Yes, I'm running that same wheel all around with 274/40s. They clear the 07 GT500 Brembos just fine.
Moving up to a 285/40 after these tires wear out.
