3v harness, parts and GT500 odds and ends
W3bb3r04
Slow 3v Member
Clinton, TN
3v harness off of 05 GT. Number 7 COP connector missing and oil temp sensor missing. Asking 200 shipped or will part out connectors for $10-20 each. Price will depend on how many are purchased and which ones.
Gt500 heat to exchanger off 2011 with 30k miles
Rear main cover $10+ shipping
Stock block plate with oil sensor- $25 shipped
Stock 3v tensioners $10 plus shipping.
3v oil pump with 900 miles on it $30 shipped.
Stock balancer $20 plus shipping
Homemade delete plates. Could use a little sprucing up but gaskets are good.
SOLD
Stock fan with 900 miles on it. Comes with resisitor.
$40 plus shipping
Innovate LC1 wideband. Has a little melt mark on connector but has worked fine for me. Comes with Roush pod and serial connector. This is the blue gauge.- SOLD
05-06 Coolant crossover- $40 plus shipping
Coolant overflow for 05-10 GT. Needs new cap. Should be able to get one from S&H.- SOLD
Timing chains, reluctor wheel and crank sprocket with 900 miles on them $30 shipped
Timing cover gasket set with front seal- $15 shipped
Rear main seal FORD PART- $10 Shipped
Ford OEM followers and Lash Adjusters with 30k miles on them $75 shipped.
Head gaskets from FRPP head changing kit -$35 shipped.
Timing cover-SOLD
3v valve covers- $35 plus shipping
Have other OEM stuff laying around as well. Intakes, 3v bare heads, valves, valve springs, retainers, valve cover grommets, throttle body etc. Selling all my spare parts. Sold the car and no longer need any stuff. Located in knoxville, TN
Sent from my HTC One_M8 using Tapatalk
05sonicblue
Windsor, CT
Waiting on quote. I will take the head gaskets and timing cover gaskets set and rear seal. And timing cover. Please pm me with info. I will pm you to remind you.
W3bb3r04
Slow 3v Member
Clinton, TN
All PMs and Sent and Replied. Only thing paid for right now is the timing cover. A lot of pending sales on everything else. Will update the OP when things sale. Thanks guys.
W3bb3r04
Slow 3v Member
Clinton, TN
PS reservoir sold. Still have all the harness if anyone is interested in the whole thing.
Jeguerra
Also interested in tensioners (2) shipped to 67205. Thank you.
W3bb3r04
Slow 3v Member
Clinton, TN
Cam covers? How much shipped to 67205. Thanks
Yes I do. I can do $75 shipped and paypald for it all.
still got the followers and lash adjusters?
Yes I do.
Sorry it took so long to respond. If anyone needs to get in touch please PM me since I get an email for that. Thanks!
W3bb3r04
Slow 3v Member
Clinton, TN
Bump. Still have all these engine odds and ends, and seals. Also have 2 sets of 05 heads with cam caps for dirt cheap if anyone is interested.
W3bb3r04
Slow 3v Member
Clinton, TN
Valve Covers Sold. Make offer on any of this other stuff. Would like to get rid of all this before it goes to the trash or in storage. Since I have a '15 none of this stuff can be used.
W3bb3r04
Slow 3v Member
Clinton, TN
Bump! Still have this stuff laying around. If anyone is interested in the 2 sets of 2005 heads I have I would let them go for $50 each set plus actual shipping. Otherwise I will probably scrap them since they are taking up space in the garage. Figure someone might want to practice porting or something. They would still be great to use and came off of running engines.
