Voltage alone is only half the data. You don't know charging AMPS. You have to FULLY charge your battery FIRST, then check charging volts, at the battery with a DVOM.
Without knowing the state of charge of your battery, the voltage readings don't mean a lot as far as diagnosing the issue. At this time, all you know is the alternator IS putting out power. It is possible that your charging system is just fine, and you are getting the borderline readings because the battery is near depleted.
