blownGTvert
Not sure I understand...The PS resivior is stock, the Kenne Bell supplied innercooler resivior was replaced with a large Roush tank. This was done when I did the 13/14 GT500 heat exchanger and pump upgrade.
Depressingly poor photo of the two reservoirs.
I understand that, but you replaced the entire reservoir.
Wow, this is super informative! I have a 2010 GT, and I am trying to put my power steering reservoir back to stock location, and installing the original factory CAI. The previous owner installed the wrong aftermarket CAI (2005 - 2009) and moved the reservoir to the radiator make it work. Anyway, can you please confirm the reservoir bracket part #?
Bang, the 2010 spec feed line for the pump fits. I will shorten it a bit on the pump side to allow it to better clear the thermostat housing... and cover it in loom. I'm going to clearance the reservoir bracket so it can go in behind the thermostat hanger and give a little more space for the radiator hose.
